| Help: how to transform these ugly beams?
You/GW have been so helpful along my whole kitchen planning process.
I thought the beams were smaller and ?prettier. Anything is better than the BOXES previous owners built around the beams.
But please, what are your ideas to make them less ugly? Here is the Right side of fireplace, wrapped in ugly BOXES.
Here is the Left side of fireplace, opened up.
See sample picture for inspiration.
Thank you very much for your help,
Here is a link that might be useful: brickton's beams
| Hi Amanda, I think the beams need to end on a wall so that the ends look embedded.. Would it be possible to build a post that the beams can end into (or look like it anyway. Maybe you could do built in cabinetry next to the post to keep the look cohesive.. |
- Posted by remodelfla (My Page) on Fri, Sep 14, 12 at 20:44
| Can't you face them in whatever wood you want and then stain/finish? |
| I would just trim around the beams to get what you want. Not sure how to deal with the one by the fireplace, is it structural? I would continue it so it ends in a wall. If the column has to stay due to being structural I would wrap it with something to make it look like a column and not a beam. Maybe put a matching one on the other side. If you did this then it could look ok to not pull the beam further to the wall, but depends on the space as whole which I'm not familiar with. |
