Read Me If You're New To GW Kitchens! [Help keep on Page 1]
Posted by buehl (My Page) on
Fri, Sep 5, 08 at 16:24
Welcome - If you are new here - you may find the following information and links helpful.
The Frequently Asked Questions (FAQ) pages contain helpful information about how to navigate this site as well as the world of kitchen renovations.
The Kitchen Forum Acronyms will help you understand some of the acronyms used frequently in posts.
The Finished Kitchens Blog has pictures and information about many GW members' finished kitchens. Not only can you see them alphabetically, but there is also a category list if you're looking for specific things like a kitchen w/a Beverage Center or a kitchen w/a mix of dark and light cabinets.
The Appliances Forum is very useful when you have questions specific to appliances.
To start off the process...take the Sweeby Test. Then, move on to Beginning a Kitchen Plan.
Other topics such as planning for storage can be found by doing a search on the forum.
Tips:
  • Before posting a question, search the forum. There's a very good chance someone has already asked the question.
  • When using the "search" function, be sure to use the search box on the bottom of the page, not the top!
  • In the Subject, the site changes the inches indicator (") to a foot indicator ('). We don't know why. To compensate, use two single qoutes and it will appear as a double quote in the Subject. Luckily, the double quote works in the message box.
  • When composing a new thread, you have a couple of options:
    • Have replies emailed to you: check the box offerring this option. However, you must have "Allow other users to send you email via forms at our site." box checked in your profile for this to work (see the "Your Profile" link at the very top of the page)
    • Insert a link: When you "preview" your message, you will be provided with two boxes for a link...one is for the link itself and the second is for the name or description of the link.
  • When using the "Clip this post" option (far upper right corner of each post, small print), remember that only the current post is clipped, not the entire thread. Also, you are allowed a maximum of 50 clippings. Once you reach this max, you will no longer be able to clip or email posts.
How are the home page and the Forum organized? (from the FAQs)
The Kitchens Forum home page lists 30 thread titles, starting with those that don't yet have a response. Then threads are listed in order of most recent response. That first page displays the last 2 hours or so of activity. (If there is no response to a thread in an hour or two, an unanswered thread starts to drop down.)
Below that are page numbers 1-67 for the total 67 pages of threads available -- capturing maybe 2 months or so of threads, less when the Forum is busy.
Below that (and at the top of the thread list) is a space for you to switch to the Conversations or Gallery "sides" - these are set up similarly but not nearly as active. Conversations and Gallery.
Next down is a Search button -- very important!
Next is a place for you to start a new thread. And finally are some instructions and links at the bottom.
Kitchen Forum "Sides"
Discussions: This is the "side" you are on. It's for on-topic discussions concerning kitchens...renovations, use of, etc.
Conversations: This is the "side" where you can post off topic threads such as regional get-togthers and non-kitchen subjects.
Gallery: This is the "side" where members often post pictures...especially if you're posting a lot or a finished kitchen.
Posting a link
There are two ways to post a link:
Using the provided boxes below the "Message" box:
  1. Insert the link in the Optional Link URL box
  2. Type in the description or name of the item being linked int the Name of the Link box
  3. If this is a new Post, then you won't see these two boxes until you "preview" your message.
To insert a link inside the "Message" box,
  1. Copy the following into the "Message" box where you want it:
    <a href= http://www.XXX/>Description</a>
  2. Next, replace the http://www.XXX/ with your link
  3. Now, replace the Description with the description (words) you want displayed with your link.
With either method, you will see your link when you "preview" your message
Posting a picture from your photo hosting account (e.g., PhotoBucket)
FAQ: Adding Pictures and Links [Note: If using PhotoBucket, copy the code from the line/box labeled "HTML Code"]
Posting a picture from somewhere other than your Photo hosting account
  1. Copy the following into the "Message" box where you want the picture to be:
    <img src="http://www.XXX/image.jpg">
  2. Next, replace the http://www.XXX/image.jpg with the address of the image.
  3. When you "preview" the message, you should see the picture
Layout Help
We often get requests to help with layouts. Many of us enjoy doing this but it would help if you can post a copy of your layout, preferably to-scale.
  • The best place to start is to draw up your kitchen (to scale, if possible) either without cabinets & appliances if you don't know where to start or w/your proposed new layout if you have something to start with. Regardless, measure and label everything...walls, ceiling height, widths of doors & windows, distances between windows, walls, doorways, etc.
  • If you cannot move plumbing or gas, mark them on your drawing as well.
  • Mark all doorways & windows (w/dimensions) and label them as to where they lead. If they're actual doors, mark how they swing.
  • It also would be helpful to see the connecting rooms, even layouts so you see how they interact with the kitchen and/or extend the kitchen feel and flow.
  • Make note of traffic flows in and out of the kitchen
Make a list of things like:
  • What are your goals? E.g., more counter space, more storage, seating in the kitchen (island? peninsula? table?), etc.
  • Do you plan to merge two rooms/areas (e.g., Nook and Kitchen into a Kitchen only)
  • Where are you flexible?
    • Can windows or doorways change size?
    • Can they be moved?
    • Can windows be raised/lowered?
    • Can any walls come down?
    • Does the sink have to be centered under a window?
    • Does it have to be under a window at all?
  • Do you bake? Do you want a coffee/tea/beverage center?
  • What appliances do you plan on having (helps to figure out work flow, work zones, and types of cabinets...upper/lower vs full height, etc.)
    • Range or Cooktop?
    • Single or Double or no Wall Oven?
    • Warming Drawer?
    • MW? (Advantium, drawer, OTR, countertop, built-in, shelf?)
    • DW? Standard or drawers? If drawers, 1 or 2?
    • Refrigerator CD or standard depth?
    • Vent Hood?
    • Other?
    Sizes of desired appliances (e.g., 30" or 36" or 48" cooktop; 36" or 42" or 48" wide or other Refrigerator? Counter depth or standard depth refrigerator, etc.)
  • Pantry: Walk-in or cabinets?
***** Very Important *****
Is there anything you:
  • Can't live without?
  • Definitely don't want?
  • Would like if you can find a way?
This information will be valuable to not only you, but also any Kitchen Designers you may hire or talk to. Additionally, if you've been haunting the site, you'll notice that we also help with almost all aspects of the remodel, including layout help.
If you do ask for help, then all of the above information will help us help you. Sometimes we stray from what you think you want to give you some ideas that you might not have thought of, but it's your kitchen and you can veto anything...we may argue for something (we're good at that!), but in the end it's what you want. And remember, we are just giving you ideas and possible layouts, in the end when you finalize your design it's whatever you want and decide on! After all, this is your kitchen! [Keep this in mind if/when you use a Kitchen Designer--it's your kitchen, not his or hers...don't let them talk you into anything unless you're sure it's what you want!]
When your kitchen is complete, please submit it to the Finished Kitchens Blog! This way your kitchen will join others in inspiring and helping newcomers!
Add your kitchen to the FKB!
Again, welcome and good luck! The journey is wild, sometimes bumpy, but fun!
Links from above:
Frequently Asked Questions (FAQ): http://kitchenforumfaq.com/
Kitchen Forum Acronyms: http://starpoohonline.com/wordpress/forum-acronyms/
Finished Kitchens Blog: http://finishedkitchens.blogspot.com/
Sweeby Test: http://starpoohonline.com/wordpress/2007/07/31/the-sweeby-test/#more-6
Beginning a Kitchen Plan: http://starpoohonline.com/wordpress/2007/08/03/beginning-a-kitchen-pla n/#more-34/
Appliances Forum: http://ths.gardenweb.com/forums/appl/
FAQ: Adding Pictures and Links: http://starpoohonline.com/wordpress/how-to-use-the-kitchen-forum/addin g-pictures-and-links/
Add your kitchen to the FKB!: http://finishedkitchens.blogspot.com/2005/10/faq.html#Adding
Planning for Storage
Here's some more useful information (I hope it's not making the message too long!)
Once you've finalized your basic design, it's time to analyze your storage needs in each zone. The results of that analysis will drive the size/configuration of your cabinets and drawers. (The following is a general write-up I've come up with...)
  1. First, make a list of everything you plan to store in your new kitchen, regardless of where it's stored now...kitchen, basement, dining room, etc.
  2. Next, take the list and group the items according to function. Will they be used during prep? cooking? baking? cleanup? Some items, like pot holders, may belong in two different zones (in this case, cooking & baking). You can either find storage between the two zones or have duplicates and store one in each zone.
  3. Now, determine where each of your zones will be (prep, cleanup, cooking, baking, storage, etc.)
  4. The next step depends on the stage you are in the design/order process...
  5. If you've already ordered your cabinets, then you will have to work with what you have. So...
    • Identify the storage potential in each zone and list them on a piece of paper with a section for each cabinet (base & upper) and one line per drawer or shelf in that cabinet. This includes your pantry for your "storage" zone.
    • Take the two lists and, while imagining yourself working in each zone, put the dishes, tools, etc. that you will be using in cabinets in that zone. Fill in the lines in the cabinet list with these items.
    If you are still in the design phase, you will have the opportunity to plan your storage to meet your needs in each zone.
    • Take your list and imagine yourself working in each zone.
    • Go through the motions to determine the best locations for each item that will be used and stored in that zone (don't forget that you will probably have both upper and lower cabinets).
    • Now that you know where to put the items, determine what the best way is to store those items (drawer, shelf, etc.) and what size (e.g., pots & pans work best in 30" or 36" drawers)
    • Lastly, transfer what you've done to your design & tweak as necessary.
You should now have a well-thought out and highly functional kitchen!
This not only helps you to "see" how things will fit, but it also will help when you move back into the kitchen...you won't have to think about it, you'll be able to just put things away. It will also be a handy "map" for everyone to help find things the first few weeks w/o having to open every drawer or door!
Oh, and don't forget the Junk Drawer! Most people end up with one, so you may as well plan for it so you at least have control over where it's located!
Common Zones, Appliances In That Zone, and Suggestions For What To Store There:
  • Storage--pantry & refrigerator--tupperware, food, wraps & plastic bags
  • Preparation--sink & trash--utensils, measuring cups/spoons, mixing bowls, colander, jello molds, cutting boards, knives, cook books, paper towels
  • Cooking--cooktop/range & MW--utensils, pot holders, trivets, pots & pans, serving dishes (platters, bowls, etc.), paper towels
  • Baking--ovens/range--utensils, pot holders, trivets, pots & pans, casserole dishes, roasting rack, cooling racks, cookie sheets, foils, rolling pin, cookie cutters, pizza stone, muffin tins, paper towels
  • Cleanup--sink & DW & trash--detergents, linens, dishes & glasses, flatware
  • Eating--island/peninsula/table/nook/DR--table linens, placemats, napkins, dishes & glasses, flatware
  • Utility--broom, dustpan, swifter, mop, cleaning supplies, cloths, flashlights, batteries, extension cords
  • Message Center--phones, charging station, directories/phone books, calendar, desk supplies, dry erase board or chalkboard
Less Common Zones:
  • Tea/Coffee Bar--coffeemaker--mugs, teas/coffees, sugar, teapot
  • Pet Zone--feeding area--food, snacks
Commonly Used Items: pots & pans, utensils, small appliances, linens, pot holders, trivets, dish detergents, "Tupperware", knives, pitchers, water bottles, vases, picnic supplies, cook books, etc.
Foods: Spices, Breads, Flours/Sugars, Teas/Coffees, Potatoes, Onions, Canned Goods, Dry Goods (rice, pasta, etc.), Cereals, Snacks
Small Appliances: Toaster, Stand and/or Hand Mixer, Blender, Breadmaker, Toaster Oven, Food Processor, Crockpot, Waffle Iron, Electric Skillet, Coffeemaker, Coffee Grinder, Ricer, Steamer
NOTE: If your ceiling or one or more of your walls is coming down, consider wiring for speakers, TV, Computer, etc.
RE: Read Me If You're New To GW Kitchens! [Help keep on Page 1]
~ bump ~
bump, back to page 1
~ bump ~
ttt
~ bump ~
~bump~ ~bump~
Bump
bump
~bump~
~bump~ ~bump~
~bump~ ~bump~ ~bump~
bump
bump
bump
bump
bump
thanks for the info.
bump...
You're welcome! And, thanks for "bumping"!
~bump~
~bump~ ~bump~
bump
~bump~
bumpity bump
~bump~
Bump
Bump
Bump
bump
Thank you for these handy tips- it makes the process that I have been avoiding seem much easier to tackle. I love the step by step feature..
bumping
~bump~
bump...
bump
~bump~
~bump~ ~bump~
* bump *
Yikes! Halfway down page 3!
And again!
bump
~bump~
bump
~bump~
~bump~ ~bump~
bump
~bump~
~bump~
bump
bump
bump
~bump~
bump
~bump~
~bump~ ~bump~
Very thorough and well done--thank you!!!
bump
~bump~
~bump~ ~bump~
~bump~ ~bump~ ~bump~ ~bump~
~bump~ ~bump~ ~bump~ ~bump~ ~bump~
~bump~ ~bump~ ~bump~ ~bump~ ~bump~ ~bump~
~bump~ ~bump~ ~bump~ ~bump~ ~bump~ ~bump~ ~bump~
Anyone can jump in with the bumping!
~bumpety~ (because I was looking for info here & it was on page 4!)
Can this OP possibly be made into a sticky at the top of page 1?
I've tried asking the Powers That Be, but they never respond to my requests (not even to say "no"!)
~bump~ ~bump~
bump
bump
bump
bump
Bump!
why am i here?
bump
bump
Fori...b/c you're helping us keep this info available to newcomers! Thanks for bumping it!
bump!
bump
lost on page three
~bump~
bump
On page 3, time to bump!
bump
bump
bump
Bump
~bump~
~bump~ ~bump~
Trying to sneak onto page 3 again...BUMP.
bump
bump
bump
bump
bump
~bump~
~bump~ ~bump~
bump
bump
Bump
~bump~
~bump~ ~bump~
bump
bump
obama
~neither~
Bumping
bump
obumpa?
bump
Bump
~bump~
bump
bump
bump
bump
bump
~bump~
Obama
okey-dokey
bumpity bump!
Bump. LOL, Revans!
To the top.
obumpa
BarACK to the top of the page.
plain old non-partisan bump
It fell to the bottom of page 2 while I was Biden my time.
Oh!Bummer! (think about it)
fell to the bottom again.
Bump
bump
bump
bump
Bam!!
bump
Bump
~bump~
~bump~ ~bump~
Bump......because we need this~~~~~~~~~~~
nudge
number 141
Bump
bump
bump
bump
bump
Bumping~~~~~~~~~~~again!
bump!
Bump
Last bump for this thread!
Please Note: This thread has reached the upper limit for the number follow-ups allowed (150). If you would like to continue this discussion, please begin a new thread using the form on the main forum page.
