| Just started gathering info and inspiration for a kitchen remodel and have some questions.
I have 8' ceilings in my kitchen nook and family room with a stupid 4 or 6' drop in height over the work area of the kitchen. In the remodel we're getting rid of the drop so the whole space will have 8'. -Can you please tell me what height or minimum height is recommended between the counter top and the base of the upper cabinets? -Can you recommend a good website or 2 that covers basic kitchen and bath design questions like this and recommended aisle space, height, clearances, lighting suggestions, "things to consider", etc so I can educate myself instead of nagging you guys with Qs like this? Thank you!
- Posted by andreak100 (My Page) on Sun, Sep 16, 12 at 14:58
| Typically, 18" between counter top and base of upper cabinets. Some people change this by an inch or two depending on individual height and so on. In the kitchen we inherited, the space is 16", I'm fine with it at 5'3", but we will go back to standard height when we redo our kitchen. Maybe someone else can suggest a website, but honestly, just by reading through here, you are going to find a tremendous number of answers to your questions. |
| This is just a general FYI for anyone considering a backsplash less than 18"........... How this affects your kitchen....
Keep in mind that if you're using an appliance on your counter, you must be sure you have room under the base cabinets to move that appliance around easily. Don't, for example, tell yourself you're only going to use it in front of your upper cabinets so you don't need to worry about its fit. In reality, you will be moving things around on your counter while you work and most likely your appliance will be moved under the cabinets at some point. You don't want to tear your light rail off or damage it (or the cabinets). Also remember that "standard" upper cabinets are 12" deep + 1" for the door...so they stick out 13" over your counter...leaving you only 12" or so of workspace in front of the upper cabinets...not much room to work in by itself! (If you have deeper upper cabinets...say 15", there's even less counter frontage in front of your upper cabinets...3" less, so 9".) Another consideration is vertical work space for you and your family. If anyone in your family is tall, you want to be careful not to make the backsplash area so short that it makes the work area cramped vertically. So, how do you determine the minimum backsplash height for your kitchen and how high to install the upper cabinets?
If you lower your upper cabinets a couple of inches, how much more can you realistically reach? The depth of one or two plates? What makes more sense is to plan your storage so that frequently used items are on the bottom shelf (or in drawers in your base cabinets) and progressively less-used items move up the wall cabinets. Another thing that will make it easier to get into upper cabinets is to make them a little deeper...say 15". Not only will it bring things in front 3" closer to you, but those 3" add a surprising amount of extra storage...and allows you to store platters and larger dinner plates in your cabinets when 12" isn't quite deep enough. |
