Anyone who has a stainless steel top stove
arbry (
Tue, Sep 25, 12 at 10:06
| This may be a stupid question but for those who have a stainless steel top I was wondering how you clean it? If something boils over and burns what do you use to remove the stain? I will soon be in the market for a new stove and want to be prepared. I know you can't use an abrasive on stainless, does oven cleaner work or do you have another secret? - do tell. |
RE: Anyone who has a stainless steel top stove
| Hi arbry, I have three methods that I use: (1) Dishsoap and water for general, everyday wipedowns (2) Baking soda and water for medium cleaning (3) Barkeepers Friend for heavy duty cleaning I chose the stainless top so that all of the appliances would "match." The grates tend to scratch the top of the stove every time they are moved and put back - whether it be a large pot that shifts or for cleaning. |
| You can also try Dawn Power Dissolver (spray gel). I had to order it directly from the P&G online store because I couldn't find it locally any more. It works well on baked-on grease (terrific on Pyrex baking dishes--spray, let sit, clean-up is much easier!), sugary stuff, etc. |
| I use a sponge with dish soap (soft side only) to pick up any big stuff, then wipe down with those stainless steel wipes maybe once a week. Then wipe down with a soft cloth and it looks brand new after! |
| I use Weimann's SS cleaner. If it's something burnt on I'll let it sit and soak a while. It usually comes right up. For easy spills, I use a damp microfiber cloth. |
| I just use methods 1 and 3 from april_love's list. I use method 1 for more than 95% of the cleaning. Method 3 takes care of the rare harder-to-remove crusty stuff. I have open burners, so spillovers never get burnt or baked on. Some splatter does get crusty and stuck on if I leave it for a couple of days. But simply wetting it will usually loosen it up. Personally, I think stainless steel is one of the easiest surfaces to clean. It's only downfall is scratching. Cleaning with the grain helps. |
| Scrub with the grain with a green scrubby with soap and water and then wipe with a hot rag. Go with the grain unless you don't care about scratches. |
| I have had the best luck with Bayes stainless cleaner. Easy to use and it does not water spot nor does it show fingerprints. |
I soak and wipe with handy wipes for light to medium spills. Hard to clean spills easily come up with oven cleaner. Look closely at models in the showroom. I noticed some were covered in scratches by mere design of the stove grates. Mine did not, and helped make my decision. Now, after 3 years, no scratches yet from grates, but I do lift and not slide those heavy grates. |
