Cabinets going in! Couple of questions...
Posted by phylhl (My Page) on
Tue, Sep 18, 12 at 10:06
Cabinet install started yesterday. So far, I love everything. We have one long wall (with a range top, modernaire hood (which I unwrapped and inspected, it's perfect), prep sink and of course uppers and lowers. The placement of the lowers is being determined by the opening on the back of the modern aire hood - has to go between the studs.
The placement of the uppers is determined by a rise in the ceiling height.
I have to decide how i want the ends of the uppers to line up with the lowers, or not. there will be a filler somewhere in the upper run and also in the lower run.
On the ends of the uppers at the far end, I will have a decorative bracket, 1" thick. Then the countertop will ultimately have a slight overhang on the right and left ends.
My question is - should the brackets line up with the edge of the lowers? In which case, the tile backsplash will end at the bracket, then come out 1" farther beneath the bracket til it hits the countertop.
Or should I go with a straight backsplash edge?
The uppers are not mounted yet until I decide, so I can't visualize or post a photo.
Any thoughts would be much appreciated!
RE: Cabinets going in! Couple of questions...
In a straight run with no corners, there shouldn't be any fillers. Upper cabinet runs should always end where the lowers do, or be slightly smaller. Decorative corbels should only be used on "hutch" or "mantle" type cabinetry to create the look of a separate piece of furniture, usually with a separate depth or color to differentiate the piece from the rest of the cabinet run. Full height backsplashes generally line up with the uppers, with a 4" piece following the counter out to it's end on the lower run and sides.
Thanks for your reply. Can you explain the last sentence please? the 4" part I'm not understanding....
Unfortunately I have to have fillers :-( or it just won't work out. Not sure how it happened, but it did. I will try for a spice pullout on the upper one, the location is perfect for that.
