| Hello,
We have very hard water in our area and the stainless steel sinks we are replacing are permanently stained as a result. Thus, DH wants me to find porcelain sinks with non-metal sink strainer/drain openings. I don't know what they're called but it's the portion that covers the drain hole at the bottom of your sink and usually includes a lift-out strainer. A quick search of the forums brought up mostly threads about garbage disposals. What are the non-metal options? Are there porcelain/ceramic drain openings? Thanks for any advice/help. |
There are lots of colors and materials available from numerous manufacturers. Here's mocha porcelain, from Elkay: Here's some copper ones to match a manufacturer's sinks
The main thing to be careful with is that you specify whether you are using a disposer or not - the flange will be shaped differently. |
| Wow, thanks so much for the helpful post! Does this mean I can order almost any kind of sink and just order the porcelain ones separately? These are going into a bar sink so we have no need for a disposal. And I did identify it by the right name? Thank you again. |
| Just thought I'd update my own thread in case others find it through the search engine to note that I found Kohler Duostrainer comes in white/black/other non-metallic finishes. Found a great deal on wayfair so I'm paying about $44 (with free shipping) for the sink strainer and tailpiece (basket sold separately but these are for toothbrushing sinks in a dental office so no need for the basket). Hooray! |
| Great and keep smiling! |
