| Okay, this is not a trick question! : ) The recent discussion on light rails and cab height above countertop got me to thinking in micro-inches. Oh yeah, not to mention 3mm vs 2mm counter tops. So I decided to change my status from lurker to poster (one post about a year ago) and ask my friends at GW my burning question. (arch is conveniently out of country) So here goes.
This is a new build. Our ceiling height will be 9 feet. The drawings that went to the structural last week clearly indicate 8 feet 11.25 inches. So that's 107.25, right? And I had been figuring 108 inches when planning for kitchen cabinets. Is this normal - will a 9' ceiling measure out 3/4" shorter? And what about the drywall? Will they need to cut it down to fit - not on my dime - or is 9' drywall short by 3/4"?? Am I over thinking this or do I need tell my architect to go back to 108"? We are still under the max height limit by about 6" so the extra 3/4" in height will not be a permitting problem. Thanks in advance for your responses. A worried Honu.
- Posted by desertsteph (My Page) on Fri, Sep 28, 12 at 1:03
| they're allowing for floor and ceiling space? |
| And what about the drywall? Will they need to cut it down to fit - not on my dime - or is 9' drywall short by 3/4"?? I don't believe there is any such thing as "9' drywall." It is 4x8 or 4x12. You generally lay it horizontally anyway (unless there is a good reason to do it otherwise). So, naively you would have 4'+4'+11.25" sections; in reality, you will probably have something like 2.5'+4'+2.5' sections. In short, YES, you are overthinking this. Insist on 108" ceilings if the extra height is important to you, but 107.25" is a perfectly valid ceiling height. |
| Wow! Thank you for answering this dumb question. It was so good to get up this morning and see your responses. @Desert Steph: Yes, you are right. I was looking at finished floor to finished ceiling. So the 3/4" must be the allowance for ceiling drywall. @Angie: Thanks for the clarification on the drywall sizes. The extra 3/4" isn't a deal breaker for me, but my current home has 10' ceilings so I am real sensitive about going lower. Though I know I will get used to it. Thank you both! Honu |
