Raised refrigerator? Why not?
deedles (
Tue, Aug 7, 12 at 23:19
This is a pic (the only one I've found thus far) of a refrigerator raised up on a drawer base. The brand is Suntouch, made for the off-grid market.
I'm not interested in the brand but I am interested in how they raise it up on drawers... why isn't this a great idea? Esp. for those 67" tall fridges with a top freezer?
I would think if you had a model with sealed coils on the back, pulling it out to clean would cease to be an issue.
I like this idea and am wondering what you all think about its feasibility? |
RE: Raised refrigerator? Why not?
| Well, you'd need a forklift in your kitchen to install it... |
| fori: lol. Actually, I thought we could just ramp it up into the hole on something ramp-like. They do have wheels, right? |
| How about laying it on its side? |
| I designed a Universal Access kitchen once (not for a real client) where I raised undercounter fridge and freezer up to "raised dishwasher height, with a pull out counter underneath each. I don't know why it couldn't be done with short units. |
| Marcolo: wouldn't that be a chest fridge, lol? I think they make those... Palimpsest: I don't know why either and I like the idea of drawers underneath. Obviously they'd need to be sturdy enough to hold the weight of the fridge but gosh, if they put a man on the moon can't we have drawers under our refrigerators? Screw that over the fridge cabinet with it's blasted inaccessibility! |
| You can't use the over the fridge cab? How would you use the top part of the fridge/freezer? That would be worse than not being able to use the cab. =) |
| The weight of a refrigerator full of food is not inconsiderable. You'd have to have a center brace and use at least 1" plywood for the cabinet box. Then you'd need access from all sides so the couple of very burly men could grasp it and lift it to the platform. Trying to slide it in a slot between cabinets on top of a box would be hazardous as they don't have any handles to grasp to aid in positioning it. Then you'd need a method of securing it so it wouldn't roll forward off of the box every time you tried to open the door. And you'd have to go through all of that rigamarole every time it needed to be serviced or you needed to clean underneath it. Not saying it can't be done, but it involves a lot of design parameters that you perhaps aren't considering. I think that unless you yourself can pick up the unit, such as a small dorm type fridge, then this isn't as user friendly a design as you imagine. Consider a French door fridge instead. It puts all of the refrigerator contents at the easiest height to get to, and then the drawer pulls out to bring all of the frozen stuff to you without you having to crouch down and hunt. |
| So, if this is a standard height fridge to start and you raise it up, that would mean that the top area of the fridge (or freezer if using a top freezer model) would have the inaccessibility issues that the over-the-fridge cabinets have, right? Also, I'm not certain how much reinforcement would need to be there for the raised box, but I'm thinking that the reinforcement would take up a significant portion of any storage space you might hope to use. Lastly, if you do pull your fridge out from time to time to clean underneath it, I think it would be almost impossible to do do so with this idea. If you're going for a smaller fridge, these concerns may not be as much of an issue, but if you're looking at a standard sized one, it might be a bit more challenging. |
| I guess I was thinking of a 30" wide standard depth recessed to counter-depth. Those are in the 67-68" height range mostly. Alright, well I asked you all to tell me why it wouldn't work so at least now I have some idea of the probable issues. I guess I was thinking about a 68" tall fridge on a 8" or so drawer base... so 76" tall overall to the top. Okay. yeah. I'll think about it some more. Dang. I liked those drawers under there.... |
| I have a freezer (admittedly small, ~5' tall) in my basement that I placed on a platform. I did it by my lonesome. First I built a stout platform out of 2x4s. Then I tilted the freezer to one side, and stuck a 2x4 under that side. Then tilted the other way, and stuck a 4x4 under that side. Then tilted the first way again, and put something larger that a 4x4, etc. Although not easy, it could be done for a full-size fridge. |
| Our last fridge was raised. Standard size, but short. 64" or 65" tall. Same as Angie, we just built a frame of 2x4's and covered with plywood covered with a piece of linoleum. Stuck a couple 2x4's and a piece of OSB down on the floor to make a ramp. Pushed it into place. Reverse process to clean underneath. Made access to produce bins and bottoms shelves so much handier, and because it had a top freezer, we didn't use for anything but a bag of ice, frozen water bottles and a handful of frozen pizzas, reaching it was no issue. |
| I knew getting in up on the drawers could be done without a forklift, lol. Thanks for the info. I've been looking at some of these fridges.. they're 84" tall! DH is 6'5" and I'm 5'8" so maybe a smaller fridge raised up would work? Just trying to find any possible area for storage. Plus, we have an old top freezer in the kitchen that will be remodeled and I "HATE" bending down digging for stuff in the fridge. I kinda like having the freezer at eye level, though and not having to pull open a big heavy drawer like in my 36" french door model. That's why I thought a top freezer lifted up might be the best of both worlds. |
| Deedles, I don't know whether you've ever used a tall bottom-door-freezer model, but we're a midge taller also and absolutely adore the accessibility of our Liebherr with a bottom door freezer. It's got drawers inside that are lightweight and easy to pull, or you can take them out entirely and just use the shelves like in the fridge proper. Check it out? |
| Hmmm, ice maker leaking into the bottom drawer...not a pretty picture. |
| Don't compressor fridges weigh more than absorption? That might be why the only photo you've found is a gas model. |
| I like this idea and I have often wondered why no one is building this. I looked into this a few years back and I even spoke to SunTouch about it. The lower drawers could be some kind of potato and onion storage volume. Before I bought my new fridge I raised by old clunker fridge onto a platform (made out of a Metro wire shelving unit). This was fun to do and was easy as pie. It was fun to open the door on a raised fridge too. When I began my renovations I had the best answer all figured out. In the end I got the kind of fridge freezer that they call "bottom freezer". This was the answer to the question. It also costed less than any other alternative. I would never go back to a top freezer model unless it were raised. Hth |
| We considered doing this to eliminate that space at the top of the fridge before the upper cabinets start. We only needed about 3-4 inches to make it look built in without a space. I looked and looked for a counter depth FD that was taller than most and found the KA model which is a couple of inches taller than all the others maybe Jennair is a little taller too (ones in our price range) and that pretty much took care of our problem, still a little bit at the top but nothing like before with the older model fridge. |
| This is really no different from washer/dryer set up. I think it should not be that hard to pull off in terms of building something stable enough to hold the weight. It doesn't spin and shake like a washer does, so if anything, it should be easier. :-) |
