Problem with Giallo Ornamental White?
Posted by rdw829 (My Page) on
Fri, Aug 31, 12 at 22:42
Our new granite was installed two weeks ago, and we just started really using it this week. They sealed it when it was installed, but I am finding that any water put on it is soaking right in! Just water, but there is a definite wet spot (it's green) - that seems to eventually go away when it dries.
Does that have a lasting effect on the granite?
Also, even after install - the counter never felt clean - it's always felt like there was a layer of grit on top. What can be done for that? (I've cleaned it as much as I can).
Granite installers are coming back tomorrow to re-seal, and I'm wondering if there is anything else I should be asking - or be on the lookout for?
RE: Problem with Giallo Ornamental White?
Any thoughts or advice?
Hi rdw829 - I did a quick search and came up with some other threads which may be helpful to you. From a quick skim, it looks like you may need to seal multiple times. Best Regards, oldbat2be
http://ths.gardenweb.com/forums/load/kitchbath/msg0522321329550.html
http://marblecleaning.org/phpkb/article.php?id=934
Here is a link that might be useful: Post with multiple threads about granite types
Sorry that 'marblecleaning' link looks like a marketing one but the paragraph about finding out whether you needed to seal your stone looked promising:
Spill some water in a couple of spots of your stone, let it dwell for 5 minutes or so, wipe it dry and observe if the areas under which the water has been sitting have become (temporarily) any darker than the rest. If so, then you will apply a good-quality impregnating sealer. If not, you won't.
I had the exact same problem when my granite was installed. It felt so gritty on the surface. I ran my hand over it and was expecting to feel all smooth and wonderful and it was awful, full of grit. I also noticed that water did not bead up.
Here is what I did after researching what to do. I got some steel wool and went around the whole kitchen with it polishing in a circular motion. Then I wiped the counters again using a cleaner/sealer countertop product. I always use this now. It helped tremendously but I still had what seemed like little pepper like things on the surface. I was told that lighter stones will shed a bit. Wrong answer. I had no idea about that. After being freaked out for about 2 or 3 months I'm fine with it now. The more you use it the less it will feel like that. It will eventually be smooth but the granite I have is very soft and full of all sorts of mica, quartz and other minerals that I'm told is my problem. I've been disappointed in the surface of it as I expected it to be completely smooth like the granite is in my master bath and laundry room but they are both dark colors.
Try the steel wool, it won't hurt it at all since it's soft and it helps remove the granite dust from fabrication. Do it before they come to reseal.
What granite do you have gr8day? Is it Giallo Ornamental too? I just picked that granite!
My GO initially did the same thing with the water. Almost looked like water spots darkening the garnite. It stopped doing it after about 6 weeks. I don't know if it was a sealing issue or a settling period. But it did stop with no residual after effects.
When the DW was on the counter above it would darken, almost like the steam was coming straight through. That doesn't happen anymore either.
I wondered if perhaps the sealant had to harden first. The gritiness feeling is long gone. I have had my GO for 2 years and I still love it. It is just very cool looking.
No, it's not GO wish it was!!! It's called Ivory Silk. I'm certain that GO is a harder stone. This stuff I have is so pitted. They even came and took the island off, took it back to their shop and repolished it, made no difference. I just have to learn to live with it. I searched for months for a granite that I loved and I have never seen this anywhere else. It almost looks like marble but oh well. It's pretty if you don't work over it and weren't the one who paid for it, lol. I think your stone will be just fine!! It's very popular(GO) and I've never heard anyone complain about it. The GO white is especially beautiful. Good luck all!
When I was having my problem I googled gritty granite and got lots of info. I had a thread about it on GW too. It's much better now. It's been in since March of this year if memory serves.
My giallo ornamentale is 2yrs old and still shows a watermark if something wet is left on it for a while. However, the wet mark fades within about 30 mins and it still looks normal afterwards, so I don't worry. This is only for water spills - other spills are wiped up right away. As for grittiness, I've found that Weiman granite polish (spray bottle put on with paper towel) takes away all grittiness and gives a nice shine.
