Mon, Aug 27, 12 at 22:22
| Is the current laundry area a closed in space or is it also a hallway to the bedrooms? |
| Oh, and where you have the word "pantry", do you mean there are pantry cabinets that open into the kitchen, or is that a pantry door over the girl's head? That area seems to jut out a bit too, or is that an illusion? |
| I also don't hate the idea of losing the brick wall and the fireplace completely, but I don't know if it's less involved to knock that out vs. move a (likely load bearing) wall. In that last photo above, you can see the support beams on the ceiling. That room is part of the addition that was done in 1981. We are in Southern California, so the fireplace will be used next to never. |
It would probably help to see the whole floorplan, but if the living room is on the side of the pantry wall, would this work? ![]() or |
| Also also, we thought about instead taking down the wall behind the oven-you can just see the edge of the interior doorway to kitchen to left of FP-, which would expand it into this room (w/ table) which is the original dining room. Too small for us to use as a dining room, so we will likely use it as a quiet reading area/place to play chess & cards. However, that puts it right off the front door, which I'm not sure is quite right, either. |
| Marti- so basically you moved the laundry wall back, but not all the way. Hmm...I do like the layout you've proposed, my only pause is that the only access to the kitchen area/backyard is through the bedroom hallway, essentially closing off the house in half. Still though, I like the second option especially, with the island. I wonder if that layout would still work with an interior doorway on that long wall? Perhaps where the oven/micro is and then just make the cooktop a slide in range? I'll work on a complete floorplan. Thank you for your input. I think you may be on the right track! |
| I like the idea of Marti's second layout. with your proposed door to LR in the spot where the MW is noted. Perhaps the island floats up and joins the range run as a peninsula. Are you open to the possibility of a prep sink in the peninsula/island? The fridge goes to left of sink, I think. You may have to play around with how far apart the sink run and the range run are to strike the right balance. |
| Is the backyard on the other side of the living room? I don't know that I'd like the house cut in half. Maybe someone can come up with something that works without limiting access. |
- Posted by remodelfla (My Page) on Tue, Aug 28, 12 at 19:30
| Would it be possible to put the dining table adjacent to the hearth area where the sink/DW/oven is and relocate the kitchen along the top wall? You could def fit an island then with seating. |
| RemodelFla- That might work. The only concern is that there is an interior doorway just to the left of the fridge. It can't be moved further down (to the left in the floorplan) as there is a staircase behind it. But there is some flexibility to move it a couple of feet, I think. I'll play around with it and post a photo. Thanks for your help! |
- Posted by lavender_lass (My Page) on Wed, Aug 29, 12 at 13:52
| Drybean- I really like your new plan! I think it will look great and that fireplace is wonderful. What style do you visualize for the kitchen? Any chance of French country? :) As for the microwave, maybe tuck it into the island? Here's one possibility...
- Posted by desertsteph (My Page) on Thu, Aug 30, 12 at 1:06
| you're ok w/losing the laundry there? and that big closet? how about a table to the left of where you have the pantry door in your last layout? you have 2 FPs? how about switching 1 or both to electric? you can have the atmosphere of a FP w/out the wood/fire mess. just flip a switch. They can also bring heat into the room if needed. |
