How wide is this pullout?
Posted by flevy (My Page) on
Wed, Aug 8, 12 at 13:05
I'm wondering if this might be a good filler but I can't figure out how wide it is?
RE: How wide is this pullout?
Looks like a 3" filler with a custom insert. Remember that fillers have to go between cabinets. If you are thinking of using that between a cabinet and an appliance for instance, you will have to have at least a 3/4" side panel to attach to runners to and that 3/4" panel will have to have a secure L bracket to attach it to the wall behind as well as some horizontal connections to the cabinet on the other side of the filler pullout.
I'm guessing a bit wider than Holly. Those look to be wider knives than parings. With the width of the door, I'd guess 6". But Holly is the pro. :)
Breezy, just looking at the pull, it doesn't look like 3" of space on either side of the door. But, to your point, it kinda does look like more than 1 1/2". Sooooo, maybe it's completely custom and is a 4 1/2" or some other non standard dimension.....
Thanks! I have 6" of dead space and I think this might just work nicely.
