Height of pot filler. Deciding today!
Posted by 2LittleFishies (My Page) on
Fri, Aug 10, 12 at 11:21
How high should the main piece be? I figure too high will splash but needs to work with larger pots.
Any advice on placement ??
Ours is the Moen Showhouse.
RE: Height of pot filler. Deciding today!
My spout is 16 inches above my stove top. This was high enough to clear my largest pot. If I have a very small pot, I will lift it to the spout, but it is a good height for 95 % of my pots. Hope this helps.
Mine is 17" up. Same reasoning as breadandsuch.
I took our big canning pot, and used that as my measurement. That's in the last kitchen. This one there is no potfiller.
Thanks, I did 15" for now (I'm short) buy GC said it can easily be moved up or down a bit later... Thanks so much!
I know it's what you want, but I never could understand a pot filler.
I dont like the idea of a faucet without a drain under it. With limited use, I wonder how stale the water gets. I'm afraid of filling a pot so that I wouldn't be able to lift to empty it....and you do have to empty it at some point which is when it's fullest, hottest and most dangerous to lift. Filling a pot with cold water isn't so scary....and that way I know I can lift it.
Just my POV FWIW.
