Suggestions for Filter Faucet
Posted by afisher0204 (My Page) on
Thu, Aug 9, 12 at 10:30
We are considering the KWC filter faucet and wanted to know if anyone has any other suggestions or ideas. thanks so much.
http://kwcamerica.com/-hansa/doc/technical/specsheet/K.18.P2.21 Spec Sheet.pdf
RE: Suggestions for Filter Faucet
If your water is bad enough that you want filtration for it, then you should skip the filter faucet and do a whole house system. Or if you just want better tasting drinking water, do a small point of use filter system in the sink cabinet. It will work better and be cheaper. Or just get a standard fridge with filtered water and ice.
