Options instead of Grout on Silgranite sink?
Posted by gemcap (My Page) on
Tue, Aug 5, 14 at 5:06
I've been reading on the "haze" that grout seems to leave on Silgranite. I need to seal my undermount sink? The GC recommended grout but I refused this based on GW feedback. Would you recommend Silicon instead of grout? Are there any other options you would consider?
Thanks
RE: Options instead of Grout on Silgranite sink?
Sorry I don't think I can answer your question without some clarification. I've never had haze on my Silgranit sinks, and I am on my 3rd one (in 3rd house). I always have had the anthracite color which doesn't show anything. Usually I have to remind myself to clean the sink cause it never looks dirty. I cannot imagine sealing a Silgranit sink, and haven't heard of that before.
I am unclear from your post what the haze comes from? What grout in sink? The only thing I can think of is that when your plumber installs the drain, the drain should be installed with silicone not putty. Putty could stain the sink from the industrial-oil base of the putty. Is that what you mean?
This post was edited by Mrs_Nyefnyef on Tue, Aug 5, 14 at 8:32
If your GC recommended grout anywhere near a composite sink, you should fire him immediately.
Silicone is applied between the sink flange and the bottom of the top, functioning as a gasket only, and held with mechanical fasteners.
The only grout haze that occurs on a sink is when your hack tiler puts thinset or grout down your sink. Your fire him,and send him the bill to clear out your pipes and replace your sink.
Or, hard water will leave a haze on any sink material. It's not exclusive to silgranite. The haze on a sink is the least of your worries with hard water. The inside of your pipes and faucets will have that buildup that never goes away. Water treatment is in order if you have hard water.
Mrs_Nyefnyef : it may be a case of a little knowledge is a dangerous thing, but one of the threads reg grout and silgranite is this
About Silgranite Sinks
live_wire_oak - The sink is being fixed last after the tiling is done but I'll keep that in mind. Thanks for the tip
Trebruchet - Not my sink but a random picture of an undermount sink from the web. The arrow shows where the grout is supposed to go which is where I told him to add silicon. Help please...
gemcap- my silgranite sink was installed the same day as the granite by the granite guys. tiling is tbd as i am diying it but my granite place told me to wait 2 weeks before tiling the bs. there is no grout needed at all on the sink. grout makes no sense to me.
is it that your installer has not worked with silgranite before? my granite place installed them frequently so they knew what to do
ardcp - the grout or silicon is the filler to prevent water seepage in the undermount sink (refer the red arrow in the picture posted)
gemcap i would go onto blanco's website to see what they say about grout vs silicone. i have never heard of anyone grouting a sink as grout is not waterproof.
The stuff that goes in that crack isn't grout--it's silicone caulk. Maybe your GC is using the wrong word?
You wouldn't even use grout on a sink that's tiled in and surrounded by it.
Caulk. Not grout.
I would never put grout in or down the drain of any kitchen sink.
"Trebruchet - Not my sink but a random picture of an undermount sink from the web. The arrow shows where the grout is supposed to go which is where I told him to add silicon. Help please…"
gemcap:
I try not to repeat myself, but I'm going to make an exception in your case. Do not, under any circumstances, put any grout whatsoever, at, near, between, around, under, or about your sink.
Silicone and grout are as different as car tires and pornography. One cannot be substituted for the other.
Have I made myself clear?
'Silicone and grout are as different as car tires and pornography."
ha ha...thanks Trebruchet :-) I so needed that laugh in the morning. GC is going to get a crystal clear hymn sheet to work off. He's a nice guy who's open to feedback and other views so that is a positive.
ardcp - he says he has worked with composite sinks before so I now wonder how the other installations turned out to be.
This post was edited by gemcap on Tue, Aug 5, 14 at 23:48
