I have a concern regarding my bianco antico granite island top. I understand that true fissures in granite can be expected as a consequence of this natural material and can present no difficulty for the function/performance of the granite. However, there is a 28 inch long disruption that completely traverses my island from the one straight long edge across to the arc on the other side. It starts about six inches in from one corner and ends about an inch in from the corner where the arc is. At each end of the disruption one can feel that it works its way all the way down the sides to the bottom of the stone. I can find nothing in combined appearance and physical attributes even similar to it on any of the rest of my countertops. Interestingly, though it is 28-inches-long in my island, it is not present in my other countertop that was continuous with this area about 9 inches away in the original slab as seen in my slab cut plan. I believe this break is a crack and not a fissure since it mostly doesn�t pass between, or interface, varying compositions within the stone, but instead cuts indiscriminately through the compositions as it travels its route. Where it does pass between compositions I think it does so because these are points of less resistance. I can see in many other locations that I do have fissures in my stone, but they are smooth on the surface. Also, the break that I am concerned about results in two reflecting planes in the surrounding polished surfaces on either side of the break. There are some raised, flaky looking areas and some pits along its way. A fingernail catches on the break on many spots as it is crossed. Another reference point to characterize this problem is that the difference in height between the surfaces of the break is even greater than that of my one installation seam on another counter. The interference within the surface polishing leads me to believe this disruption occurred after the surface was polished. I am really concerned that this could always be an anxiety for me because of the possibility of liquids soaking in possibly leading to staining or, even worse, having the potential for the edge to crumble and eventually break off altogether. Besides all the mechanical/functional concerns, I am extremely disappointed with the appearance of the features described above and I believe the installer should have reasonably considered avoiding this area because it would probably develop into a questionable area. Instead of appreciating the overall beauty of the whole job and my new kitchen, which I have worked a year and spent a lot of money on, I can�t help but focus on this crack because it is showcased in the center of the kitchen.
Info I found on difference between a crack and a fissure:
https://www.youtube.com/watch?v=UUyU_WboV5I
I believe my island granite meets all the criteria from the June 2007 edition of Stone Business magazine as referenced in the Paramount Granite Blog :
http://www.paramountgranite.com/blog/2007/06/26/the-great-debate�fissure-or-crack/
I am at a point where I just want to know what I am dealing with and what options there are.
I am including the following link to pictures of my island:
http://s1270.photobucket.com/user/allwood123/library/?sort=3&page=1
Note that the different reflective planes can be seen by toggling back and forth between some pairs of the pictures in the sequence. The horizontal lines coming in from the light outside are the image of the straight lines of the vinyl siding on the house next door. They help to show that the light reflects on two different planes as the granite surface disruption distorts the reflection of the lines. Sorry for so many pictures, but I am including so many pictures to give as complete an overall picture as I can.
Please let me know what you think can be done. Any and all help is greatly appreciated. I am extremely grateful for the opinions you provide.
carsonheim
Joseph Corlett, LLC
Freehold Kitchen & Bathroom Designers · Gainesville Kitchen & Bathroom Designers · New Castle Kitchen & Bathroom Designers · Elk Grove Kitchen & Bathroom Remodelers · Fort Myers Kitchen & Bathroom Remodelers · Garden Grove Kitchen & Bathroom Remodelers · Kendale Lakes Kitchen & Bathroom Remodelers · Kuna Kitchen & Bathroom Remodelers · Los Alamitos Kitchen & Bathroom Remodelers · Pueblo Kitchen & Bathroom Remodelers · South Lake Tahoe Kitchen & Bathroom Remodelers · Middlesex Kitchen & Bathroom Remodelers · Lindenhurst Cabinets & Cabinetry · Wadsworth Cabinets & Cabinetry · Eastchester Tile and Stone Contractorsdcward89
lazy_gardens
allwood123Original Author
gr8daygw
Granite City Services
Stoneshine
