Does your fabricator require visual inspection of the range?
Posted by thedork (My Page) on
Wed, Jul 3, 13 at 15:08
I need to order the appliances then in advance and the range to be in the house somewhere so they can inspect before cutting? Thank you!
RE: Does your fabricator require visual inspection of the range?
I needed to have the appliances on site for templating.
Got it! Thank you! I have an in house delivery so I wanted them to be in the house not the garage - my space is small but I guess I need to figure something out.
Really? My fabricator just needed the sink. They didn't look at anything else when they did the template.
I needed to have my rangetop and sinks onsite for templating. They all happened to be in the house at the time. The templater looked at n measured the rangetop and took the sink with him back to the shop when he left.
My fabricator wanted the same thing as breezy's. Everything needed to be on site, and he took the sinks back to his shop.
Laura
Having the range on site is a very good idea - you'll get a much better fit with the counter.
Thank you all! I will schedule the delivery before counter install.
No no! Appliances should be onsite before the template not the install! The install is too late to account for any individual size differences that the manufacturer "forgot" to put into their documentation.
Yes, the template - thank you!
I had my appliances, sink and faucet all here before the template - that way if there are issues later on, the fabricator cannot use the excuse that he did not have everything there and had to go by "spec."
