| Does antique brown need to be sealed or not? TIA |
| From Bill Vincent (Mon, Mar 9, 09 at 9:54) "... A lot of times, when this discussion comes up about sealing granite, I'll refer people to a page in that site that has links for two sets of tables-- one A-L, and the other, M-Z, listing the names of the more common "granites". One of the things they list on those pages is the absorption rate of each stone, and anything with less than a .25% absorption rate should NOT be sealed. ..." |
| Now that I've linked to the FindStone site, I realize antique brown isn't listed! However, for any stone you can check for the need for sealing by doing the "sponge test"... Again, from Bill Vincent (Mon, Mar 9, 09 at 13:32) "... the "sponge" test. That is, to drop a sopping wet sponge or rag on the stone, and allow it to sit for a couple of minutes. You then remove the sponge and wipe up any water left on the stone. If it leaves a dark mark, you'll need to seal it. ..." Another way to tell is if water beads up on the surface. If it does, it probably does not need sealing. But I would do the "Sponge Test" to be sure. |
Here is a link that might be useful: Read Me If You're New To GW Kitchens!
| Hi Galleycook, What did your installer say to do? I just posted this -------------- Hi Shilohsmom, Normally granite is sealed at the factory but should still I have Virginia Jet Mist honed granite that is known to be My installer told me I had to wash the counters and not There are also directions on the sealer products that you My installer recommended I seal my counters once a year. I have a family that is clumbsy and is known to spill Why should I be concerned about oil on the counter? Well I hope this helps. If not check out those links and maybe Oh dear, I remember someone having a white ghostly haze Granite was sealed and has haze HELP About Sealing Granite counters http://homerenovations.about.com/od/kitchens/f/sealgranite.htm How to Seal granite from EHow http://www.ehow.com/how_2106339_seal-granite-countertop.html Granite Sealer a different product that what I used Here is a link that might be useful: Sealing Granite |
| "Normally granite is sealed at the factory but should still be sealed once installed in your home. " NOT all granites require sealing. If you seal one that does not absorb the sealer forms a film on the surface of the stone and will quickly look splotchy and uneven as it wears away from normal use and cleaning. |
- Posted by galleycook (My Page) on Fri, Jul 9, 10 at 20:24
| Thanks, Buehl, Boxerpups, and Brickeyee. I wasn't able to find out whether or not antique brown should be sealed. The fabricator is of the position that all granite should be sealed (though I know from my research and testing of stones that isn't true). I also ran all the tests on a sample (lemon, vinegar, oil) and it seemed to be bulletproof. At this point, though, to seal or not to seal, is the least of our problems. I'm going to run a new post - when my head stops spinning - to request help sorting out the latest issue. Thanks, though, for taking the time and care to respond to my request, this morning. You are the best! |
| Question: an earlier post in this thread indicated that if you leave a wet sponge on the granite and it leaves a dark spot, it needs to be sealed. Well, my giallo ornamental does exactly that. I also have a stain I've been trying to remove via the baking soda approach - I'm on the 3rd attempt. It's been 2 months since installed, and the fabricator said it was sealed prior to installation. Sounds like I need to reseal it? |
