| I hope it is okay to post this here!
Celticmoon, I saw your threads earlier about gel stain on your cabinets, and may I say I was awed and inspired! I rushed right out to get gel stain to refinish these yellow birch cabinets I have. My first attempt was extremely blotchy. I thought maybe this was because there is very little finish on these cabs, so I put a quick coat of spray poly on and tried again. This version is much better but still not smooth enough. I wondered if you'd take a look and give me some advice? Here is my photo: Thanks, Anita |
- Posted by projectsneverend (My Page) on Sun, Jun 8, 08 at 22:09
| I'm not celticmoon, but I did do my cabs with gel stain, too. Are you using general finishes brand? I found a HUGE difference between valspar (for example) and gf. It almost looks like it's absorbing too much. I was chatting with the salesman when I bought my gel stain and remember him saying on certain woods, it's helpful to apply the topcoat FIRST, then, while it's still wet, apply the stain. Backwards, but he said it goes on just beautifully and doesn't end up so splotchy. So maybe that would be something for you to try! good luck! |
- Posted by projectsneverend (My Page) on Sun, Jun 8, 08 at 22:16
| btw - I should add that celticmoon awed and inspired me, too! This site is so helpful. |
- Posted by celticmoon (My Page) on Mon, Jun 9, 08 at 13:48
| Hi! I agree with Projectsneverend that the type of product makes a difference. I favor General Finishes. Much better than say Minwax Polyshades. Good point on the absorption too. The gels (not the pure stain but the color/top coat combo gels) sit on the surface. They are kinda transluscent. So both a difference in the surface finish integrity AND the thickness of the coat can make it blotchier. Not sure which is happening for you. The darker the end goal color, the less this matters. If you are planning to go pretty dark as a final color, no worries. Just layer on another coat or two and it will likely even out. If you are trying for a mid tone, then you may have to experiment a bit. The store guy spoke to making the surface consistant by sealing it first with a clear coat. That makes sense. Then you will have to come up with a 'wipe on, wipe off' application method that leaves an even coat. The hard part will be moving toward the end color you want but not overshooting it. (What I did was likely easier because I went so very dark - I couldn't overshoot it) The picture looks like you might be applying bits of gel in small areas. Maybe try taking a good gob of the stuff on your (plastic gloved and socked) hand and smear it end to end, then wipe end to end. Generous gobs. Big strokes. See if that works better for you. Come back and update. HTH. And if you haven't found it here, I can email you a detailed step by step. Good luck! |
Here is a link that might be useful: pix of my project
| I'm tellin' ya folks, it is MUCH tougher to get good results with a gel than a real stain or danish oil. |
- Posted by celticmoon (My Page) on Mon, Jun 9, 08 at 17:20
| Absolutely, Oruboris. Problem though, is that you need bare wood for staining or oiling. And with existing cabinets, that means stripping - a Herculean task I would never recommend. (Been there, done that.) Like painting, overcoating with gel can be a good cosmetic fix - so long as the surface is well prepared and you are going dark enough. |
- Posted by projectsneverend (My Page) on Tue, Jun 10, 08 at 0:05
| I think I got pretty decent results... see linky... (please excuse my 'jel' stain error!) Not that my pictures really do justice. I think it looks better in person. Celticmoon- your kitchen is beautiful. Sorry to hijack. Good luck nomoreblue! Come back and post pics! |
Here is a link that might be useful: My kitchen revamp
| Celticmoon! I'd LOVE your detailed instructions to stain my cabinets - including the brand & color!!! It's just what I want.I've been putting off doing my cabinets for 2 years because I couldn't figure out the best/easiest/most economical way to do so. I've tried overstaining/glazing on my matching laundry room cabs & they look terrible! I had almost given up & thought to paint. Please HELP. Although I joined this forum a year ago, I've never posted. How can you e-mail to me? |
- Posted by celticmoon (My Page) on Sat, Jun 21, 08 at 13:59
| Csquared, I got an email I think was from you, but it said I couldn't answer because your email is private. Ditto when I tried to email through your name here. With apologies for the length of this, I'm just gonna paste the whole bit here for you. You are welcome to this writeup I did a while back. A couple people tried Here's more than you need to know: My cabinets are frameless, good condition and good layout. But the finish I looked into changing out cabinets, but that was way too much money, since First I tried Minwax Polyshades. Dicey product. Hard to brush on neatly, SHOPPING LIST: Rockler woodworking stores are a good place to find the General Finish SETUP AND PLANNING: PREPARATION: STAINING: But first put on work clothes, tie up your hair (Tom, you may skip this Repeat with Java gel. This is thicker and poly based (*not water cleanup!*= Repeat with clear gel top coat. This will give you the strength you need in Do the same process with the cabinet sides, face and toekick area. Might NOTE: The cloth or socks used for the gels are very flammable! Collect and FINISHING AND REASSEMBLY: FINAL THOUGHTS: This is a pretty easy project to do. Hard to screw it up. The worst is the I added smashing hardware, raised my passthrough, resurfaced the Corian Link to cabinets in progress: Link to almost finished cabinet pix: Good luck with your project!! Feel free to ask me any questions as you go. |
| Nice write-up, Celticmoon. I'm clipping and saving this stuff. Good job! Red |
| Thank you for the inspiration(s)! -Lena |
- Posted by cheekychic (My Page) on Tue, Sep 20, 11 at 18:35
| LOVE the kitchen! I have oak throughout my house, built in '84 and might go gel stain crazy. Thank you for posting the steps. By the way, Celticmoon, did you have to have someone raise your cabinets or is there another "step by step process" for that? |
| this POST is timeless! I am getting ready to refinish two pieces that I want to be dark mahogany-like finish. And this thread referred on another thread led me to read all this information. I will try this method, or close to it to make my life easier and the project of unifying my finishes more unified. Thank you so much celticmoon, for sharing your process and inspiring those who want to upgrade a common or outdated look on pieces in our home! |
- Posted by celticmoon (My Page) on Sat, Aug 25, 12 at 15:40
| You are welcome, mary ruth. Finish is still holding up pretty well. I think I have done touchups twice in the last 5 years. BTW a friend had several dressers painted dark red, and she went over that with Java. That resulted in a very mahogany-like look. |
