Installation of slate tile floor
cmarrinerb
9 years ago
KITCHEN BACKSPLASHESHow to Install a Tile Backsplash
If you've got a steady hand, a few easy-to-find supplies and patience, you can install a tile backsplash in a kitchen or bathroom
Full StoryREMODELING GUIDESFinishing Touches: Pro Tricks for Installing Fixtures in Your Tile
Cracked tile, broken drill bits and sloppy-looking fixture installations? Not when you follow these pro tips
Full StoryREMODELING GUIDESContractor Tips: How to Install Tile
Before you pick up a single tile, pull from these tips for expert results
Full StoryREMODELING GUIDESInspiring Materials: Slate Tile
Texture, Color and Strength Makes Slate a Go-To Material for Inside and Out
Full StoryREMODELING GUIDESRanch House Remodel: Installing the Interior Finishes
Renovation Diary, Part 5: Check in on a Florida remodel as the bamboo flooring is laid, the bathroom tiles are set and more
Full StoryREMODELING GUIDESYour Floor: How to Find Right Stone Tile
Get the Pros and Cons of Slate, Travertine, Sandstone, Marble and Granite
Full StoryBATHROOM DESIGNHow to Match Tile Heights for a Perfect Installation
Irregular tile heights can mar the look of your bathroom. Here's how to counter the differences
Full StoryMATERIALSThe Most Popular Roofing Material is Affordable and Easy to Install
Asphalt shingles, the most widely used roof material in the U.S. are reliable and efficient, and may be right for you
Full StoryBATHROOM DESIGNHow to Install a Toilet in an Hour
Putting a new commode in a bathroom or powder room yourself saves plumber fees, and it's less scary than you might expect
Full StoryBATHROOM DESIGNShould You Install a Urinal at Home?
Wall-mounted pit stops are handy in more than just man caves — and they can look better than you might think
GreenDesigns
Joseph Corlett, LLC
East Islip Kitchen & Bathroom Designers · El Sobrante Kitchen & Bathroom Designers · Fox Lake Kitchen & Bathroom Designers · Georgetown Kitchen & Bathroom Designers · Wesley Chapel Kitchen & Bathroom Designers · Holden Kitchen & Bathroom Remodelers · Fullerton Kitchen & Bathroom Remodelers · Beaverton Kitchen & Bathroom Remodelers · Plant City Kitchen & Bathroom Remodelers · Cave Spring Kitchen & Bathroom Remodelers · Ridgefield Park Kitchen & Bathroom Remodelers · Crestview Cabinets & Cabinetry · Kentwood Cabinets & Cabinetry · Riverdale Design-Build Firms · Woodland Design-Build FirmscmarrinerbOriginal Author
StoneTech
kevdp4
pricklypearcactus
