Is your dishwasher attached to your granite or the countertops?
lynw (
Fri, Jun 13, 08 at 11:37
| Just a quick question - Granite people say dishwasher should be attached to the cabinets. Plumber says it should be attached to the granite. Thoughts? Appreciate your help. By the way the kitchenaid installation manual says attach to cabinets for a granite countertop. |
RE: Is your dishwasher attached to your granite or the countertop
| Definitely attach it to the cabinets if you have that option - your plumber is wrong. |
| Mine is attached to a small strip of wood set into a groove routed into the bottom of the granite in front of the dishwasher. My granite fabricators/installers and KD did a good job with appliances. |
| attach to the cabinets is my opinion. |
| The wood attached to the granite that momj47 suggests is a good second choice if you have a DW that can't be attached to the side cabinets - but your KA can! You definitely don't want to drill holes into the granite. |
| My carpenter attached the dishwasher on the side to the cabinets. He was afraid to try to attach original clips to the soapstone countertop and so wasn't I. |
| My DW is attached to the Quartz countertop. The plumber used clips and epoxy the counter guys gave him, he epoxied the clips to the underside of the countertop and then attached the dw to it with screws. He may have asked the countertop guys what to do and it apparently was OK with them attaching it to the countertop since they gave him the supplies. Sue |
| We built a cabinet for the dishwasher. This has a plywood top to which the dishwasher attaches with screws. Nothing is attached to the stone. |
| Ditto to pharaoh's answer. |
| Don't even give it a second thought, attach to the cabinets. |
| My plumber said the same thing. It seems go against prevailing thought here, but our granite fabricator did drill small holes in the granite, which the dishwasher is now attached to. |
| I have a KA and it is attached to the cabinets. If you attach it to the countertop, you may have trouble getting it in and out if you need to service the DW. The tabs on the top can come off and go on the side and then attach to the sides of the cabinets. Very easy. |
| Typically the cabinet has a horizontal 1X2 piece of wood across the top of the DW opening that the DW attaches to. I have never seen a DW connect directly into a countertop. |
| Our fabricator said it can be done either way but suggested we plan on attaching to the cabinets. We have yet to select the granite :( |
| Mine is attached just like momj47's. They milled out a strip from the granite and filled it in with wood and resin and attached the DW to the wood. |
| We did 90% of the kitchen remodel ourselves, but not the granite instln. We found brackets on-line that attach to our KA dishwasher and then attach to the floor, prevents the dishwasher from tipping when the door is opened. They're a KA item, and attach to the back of the washer. |
