New To Kitchens? Posting Pics? Read Me! [Help keep on Page 1]
Posted by buehl (My Page) on
Tue, May 29, 12 at 23:02
Welcome! If you are new to the Kitchens Forum, you may find the following information and links helpful.
The Frequently Asked Questions (FAQ)/Articles pages contain helpful information about how to navigate this site as well as the world of kitchen renovations.
The Kitchen Forum Acronyms will help you understand some of the acronyms used frequently in posts.
The Finished Kitchens Blog has pictures and information about many GW members' finished kitchens. Not only can you see them alphabetically, but there is also a category list if you're looking for specific things like a kitchen w/a Beverage Center or a kitchen w/a mix of dark and light cabinets. Access the FKB Categories Page via a link in the navigation panel on the right of any FKB page. Additionally, there is also a link to "In-Progress Kitchens" for those members' kitchens that are not quite ready for the FKB. There is also a link to "Coming Soon Kitchens" for those kitchens that are ready for the FKB but have not yet been added. To access the "In-Progress Kitchens", the "Coming Soon Kitchens", and the "FKB Categories", see the links in the navigation panel that is on the right side of each main FKB page.
The Appliances Forum is very useful when you have questions specific to appliances.
To start off the kitchen remodel process...take the Sweeby Test. Then, move on to Beginning a Kitchen Plan.
Other topics such as layouts, planning for storage, and stone materials are discussed in later topics in this thread. Even more information can be found by doing a search on the forum.
Tips:
  • Before posting a question, please search the forum. There's a very good chance someone has already asked the question.
  • When using the "search" function, be sure to use the search box on the bottom of the page, not the top!
  • Note, however, that you will probably have better luck searching if you use Google (or similar search engine) than if you use the Forum search function. When using Google, to limit your results to Garden Web, include the following in your search criteria: ***site:ths.gardenweb.com
  • In the Subject, the site changes the double quote used as the inches indicator (") to a single quote ('). We don't know why. To compensate, use two single quotes and it will appear as a double quote in the Subject. Luckily, the double quote works in the message box.
  • When composing a new thread, you have a couple of options:
    • Have replies emailed to you: check the box offering this option. However, you must have "Allow other users to send you email via forms at our site." box checked in your profile for this to work (see the "Your Profile" link at the very top of the page) [See the post later in this thread with the Subject: Getting Emails Sent To You...3-step Process]
    • Insert a link: When you "preview" your message, you will be provided with two boxes for a link...one is for the link itself and the second is for the name or description of the link.
  • When using the "Clip this post" option (far upper right corner of each post, small print), remember that only the current post is clipped, not the entire thread. Also, you are allowed a maximum of 50 clippings. Once you reach this max, you will no longer be able to clip or email posts.
How are the home page and the Forum organized? (based on the Kitchen Forum's FAQs entries)
  • The Kitchens Forum home page lists 30 thread titles, starting with those that don't yet have a response. After the unanswered threads, threads are listed in order of most recent response. That first page displays the last 2 hours or so of activity. (If there is no response to a thread in an hour or two, the unanswered thread usually starts to drop.)
  • Below the thread list are page numbers 1-67 for the total 67 pages of threads available -- capturing maybe 2 months or so of threads, less when the Forum is busy.
  • Below that (and at the top of the thread list as well) is a space for you to switch to the Conversations or Gallery "sides" - these are set up similarly but are not nearly as active.
  • Next down is a Search box -- very important! This is also the Search box you should use (not the one at the top of the page.)
    • Always refresh the page two or three times b/f assuming a thread has disappeared right after starting it.
    • As to searching...a thread will not be found doing a GW search for up to 24 hours after it has been started. This may seem too technical, but...searches are done against what are known as "indexes". Indexes use key fields/words to find things. iVillage only indexes threads once a day. So, that means that until your thread is "indexed", it won't show up in a search. If you start a thread just before the index is taken, you will be able to retrieve your thread by searching soon after creation. If, however, you start your thread right after the daily index, then you will have to wait almost 24 hours for the next index.
  • Next is a place for you to start a new thread. And finally there are some instructions and links at the bottom.
Kitchen Forum "Sides"
Discussions: This is the "side" you are on. It is for on-topic discussions concerning kitchens...renovations, use of, etc.
Conversations: This is the "side" where you can post off topic threads such as regional get-togethers and non-kitchen subjects.
Gallery: This is the "side" where members often post pictures...especially if you're posting a lot or a finished kitchen. (Note: This is where StarPooh, our FKB person, wants you to post your finished kitchen prior to having it added to the FKB.)
Again, welcome and good luck! The journey is wild, sometimes bumpy, but fun and very rewarding in the end!
How THIS thread is organized
To make this thread more readable and to make it easier to find a specific topic, I have created separate threads for each topic and just point/link to them from here.
We will continue to bump this thread, but not the other threads I created. Please, do not bump the "subject" threads I will be linking to from here. We do not want to flood the first page with all those threads. To do so would knock threads from members asking for help, etc. off the first page and would be counter-productive!
Note: The subject threads have long since "fallen off" the thread list, so no amount of bumping or question asking will bring them back to the thread list. If you have questions, please start a new thread with your question.
Posting a Link
Posting Pictures
Layout Help?
The following thread contains the information we need to help you find a layout that works for you and your family as well as how to draw up and label a floor plan.
http://ths.gardenweb.com/forums/load/kitchbath/msg010521247761.html
What are zones and how do you design with them in mind?
http://ths.gardenweb.com/forums/load/kitchbath/msg0508230128712.html
A piece of advice:
When you post a layout for comments, please do not take the comments you receive personally. Everyone here is trying to help, not criticize maliciously. We want you to have a kitchen that, in the end, functions wonderfully well and looks nice overall. This may mean that some of us may tear apart your layout and rebuild it to what we think will work better, but it's done with good intentions. We're not the best at just "validating" someones layout, we're best at critiquing!
I will warn you that most of us here are "function over form" (or "function first")...meaning we strive first for a functional layout and then fit the form or look around it. It is far easier to make a functional kitchen look nice than it is to make a nice looking but dysfunctional kitchen functional. So, if you are a form/looks over function person, be sure to state that when you post.
Some people here think "function over form" means that we want all kitchens to look the same....not true! What we do want is all kitchens to function well...which means that in 99% of the cases, the workflow is the same...so that will mean some similarities due to workflow. However, as each kitchen is unique, each will have its own unique quirks, etc.
In the end, remember this is your kitchen. You don't have to make any of the recommended changes if you don't want to!
[Note: If you're just posting for validation of your layout (i.e., you don't want comments that suggest changes), state that as well. If you don't, people will comment on it!
Warning: People may comment anyway, it's tough to let a kitchen go that you think is dysfunctional and will cause angst later...especially if it's not yet installed and we think we can help. Bear with us, we're just trying to help!]
The Next Step...Planning For Storage
Planning your storage, including where items are commonly stored.
http://ths.gardenweb.com/forums/load/kitchbath/msg010523449014.html
Miscellaneous Information
Contains:
  • Links from the "Read Me" thread
  • Pantries
  • Useful Information (NKBA links, Other Forums)
  • Helpful Threads (a myriad of past & present threads containing useful/helpful information)
  • Tile Information.
  • Stone Information (how to shop/test/install stone counters, how to remove stains)
  • Cleaning Your Kitchen
  • Custom Cabinetmaker Sample Agreement
    http://ths.gardenweb.com/forums/load/kitchbath/msg0105344116836.html
  •  o
    Bookmarking & Saving Threads
    Bookmarking threads so you can find them later or saving them so you have them (and associated pictures) ''forever''
    http://ths.gardenweb.com/forums/load/kitchbath/msg0105292031876.html
    Eliminating Those Pesky Inline Links in Messages (Advertisements)
    How to Seal Your Stone
    Steps to sealing a stone surface, if it needs it.
    http://ths.gardenweb.com/forums/load/kitchbath/msg0105254810134.html
    Gel Stain Instructions
    RE: New To Kitchens? Posting Pics? Read Me! [Help keep on Page 1
    first bump
    second bump
    bump
    bumpity
    bumpity bump
    bumpity bump bump
    bumpity bump bump bump.
    bumpity bump bump bump bump
    bumpity bump bump bump bump bump
    bumpity bump bump bump bump bump bump
    bumpity bump bump bump bump bump bump bump
    Hey Angie, you can't have all the bumps!
    bump
    bump
    bump
    caught ya!
    ***bump***
    bumpity
    bumpity bump (Nearly on pg. 3!)
    ~bump~
    bumpity
    Bump
    bump
    bump
    bumpity bump
    Bump bump
    bump
    bumpity bump
    bumpity bump bump
    bumpity bump bump bump bumpity bump
    bumpity bump bump bump bumpity bump bump
    bumpity bump bump bump bumpity bump bump bump
    buehl,
    I can't seem to upload multiple pics in the same message. What am I doing wrong? Thanks!
    Bump
    bump
    bump
    bump bump (How the heck did you make it to Pg. 3 so quickly?)
    bump
    bumpity
    bumpity bump
    bumpity bump bump (on pg 3 again, you devil!)
    bump
    Bump
    bumpie
    bumpity
    bumpity bump
    bumpity bump bump
    bump
    bump
    Bump
    bump
    pmuB
    back you go
    bump
    bump
    bump
    bumpity bump
    bumpity bump bump
    bump
    bum p
    bump
    bumpity bump
    bump
    Friday night bump bump.
    saturday night bump
    bump
    bimp
    bumpity bimp
    bumpity bimp bump
    bumpity bimp bump bimp
    Monday afternoon (pacific time) boooo-mpa!
    bumpa
    boooompa
    bumpity bump bump
    ~bump~
    bump
    bump
    bumpity
    bump
    boompa
    boompa bump
    Rainy Friday morning bump. Yes, it rains in late June where I live. ((sigh))
    Bumping
    bump
    bump
    bumpity bump
    And a rainy Monday morning bump. Again....use, it occasionally rains where I live on July 2. Usually on July 4 also.
    I love where I live though! :-)
    What I wouldn't give for some rain here!! We have had essentially zero rain since May.
    OMG! We DID have a little rain this morning. Amazing. It was just a brief cloudburst, raining hard for a minute or two, but it seems like a flood compared to the last 6 weeks.
    Well, that morning rain is a distant memory. 100 deg heat and blazing sunshine now.
    bump - wish Colorado, Wyoming, Utah and Montana would get some rain to put out the fires...
    Bump- in celebration of my finally figuring out how to put pics IN a post
    ~bump~
    bump
    Angie--Sounds like your rain just washed the faces of your plants. Wish I could send some of my rain your way! Or down/over to Colorado. I think ours has finally stopped. Beautiful day today and low 80's by the weekend.
    Breezy, that would be much appreciated! As much as I would like it, I think Colorado gets first dibs!
    Bumpity bump. Another 100 deg. day today.
    Bump
    bump
    bump
    bump
    bump
    ~bump~
    bumpity
    bumpity bump
    bumpity bump bump
    bump
    Sorry for your heat, Angie. Here in the PNW, we are finally just breaking the 80's! And that's plenty hot enough for me.
    So excited. Am told our permit has been (verbally) approved. Hope to be posting here soon for kitchen advice!
    Thanks, Breezy. The heat has broken, and it is actually quite pleasant now!
    bumpity bump
    bumpity bump bump
    bump
    bump
    Bump
    bumpity
    bumpity bump
    bump
    bump
    ***bump***
    bump
    bump
    bump
    bump. It rained here today! First real rain in so so long. Yay!
    bumpity bump
    bumpity bump bump
    bumpity bump bump bump bumpity bump bump bumpity
    And, to close out the thread,
    bumpity bump bump bump bumpity bump bump bumpity bump!
    Please Note: This thread has reached the upper limit for the number follow-ups allowed (150). If you would like to continue this discussion, please begin a new thread using the form on the main forum page.
