AngieDIY, rococogurl, breezy et all: faucet for Precis Cascade?
This is the sink I am purchasing for our remodel Blanco 519452:
{{gwi:1845264}}
I read many GW posts and Attic mag on how to select a faucet to minimize splash (key for me) and maximize function. Here's how I figure it with this Precis Cascade 18 1/8" by 23 3/4" sink:
Standard 24" counter top, minimum 3" CT surround all edges.
Here's my calculations (taken from AngieDIY's guidelines):
1. Front sink cabinet width is 3/4" so 18 1/8" width+6/8"=18 7/8" width from front sink base at a minimum to rear edge of sink.
2. Rear edge of sink from front sink base is 24"-18 7/8"=5 1/8" left for typical deck mount of faucet. Back splash 3/8" tile and 1/8" thin set=4/8". Thus minimal rear edge of sink will be 5 1/8"-4/8"=4 5/8" from typical back splash.
3. Adjustments due to CT: this puzzles me. I understand 3" surround of a sink is minimum needed to avoid risk of granite/marble cracking. A 24" deep counter top-6" (front and rear) is 18" sink width maximum (the Precis Cascade is 18 1/8"). If 3" of CT is dedicated to front, then 18 1/8" for sink width itself, that leaves 2 7/8" for the rear deck only. Obviously something not quite right here.
4. Precis Cascade's drain is center rear 4 3/4" from rear of sink. I'd like to hit the drain/GD or just in front of it to minimize splash. Given depth of deck at about 3" maximum, centering typical 1 3/8" faucet hole would place faucet 1 5/8" from rear edge of sink (2 8/8" -1 3/8" =1 5/8").
For water to hit in vicinity of drain or just in front, it's 4 6/8" drain to sink rear + 1 5/8" CT deck placement =6 3/8" reach to center of drain. That's a very short distance in faucet reach (smallest reach I've looked at is 7 1/2").
The Precis Cascade 519452 under-mount will mean 8 7/8" depth for the main sink (19 1/4"), with a sink connecting 3/4" raised lip, then 6 1/2" depth to smaller 7 1/2" sink length. Spout height selection strikes me as optimally in 8" range to minimize splash and should be a narrow (not splayed) spout head.
Height of faucet for transitional kitchen with 18" in adjacent cabinets and 24" over the sink cabinet proportion wise suggests a tight reach goose neck or 90 degree faucet. I'm thinking stainless, satin nickel or brushed finish due to close proximity to range on same side.
Would you check my numbers and weigh in on these faucets and offer comments on above and alternatives? I'm thinking tried and true good quality faucets: Blanco (due to same manufacturer as sink so tested), Hansgrohe, Grohe and possibly Kohler. Pull down/out, great magnet (like newer style of magnet within the neck to minimize hanging spout), water conservation minimum of 1.8 but I prefer 2.2 gpm, brass base, minimal plastics, reach 7.5 to 8" or so max due to rear mounting constraints, height 16" max, spout height in 8" range.
Thank you for reviewing my math. I've visited stores, touched, played with, discussed, checked reach, color (stainless or brushed). Hours spent, no firm decision, time is passing. I'm stuck on faucets for this Blanco Precis Cascade sink.
Blanco Alta in satin:more modern than desired but shown by Blanco with this sink- reach 8" spout height 6 1/8", faucet heigh 8 3/8" (limiting factor for me):
Blanco Grace II: new Blanco model, haven't been able to see in person at dealers, traditional in style but 8 1/2" reach and 8 18" spout height (thinking splashing); height 16 1/8":
BLANCO ACCLAIM™ with pullout spray-sleek, height of 14 5/8" (short for above sink cab at 24") and 7 1/2" but 12 3/4" spout height (definite splash):
Hansgrohe Talis S HighArc Model : 83/4" reach, 8 7/8" spout height, 16 1/4" height. Nice choice, but concerned about splashing given sink depth.
angie_diy
breezygirl
Arcadia Kitchen & Bathroom Designers · Arlington Kitchen & Bathroom Designers · Four Corners Kitchen & Bathroom Designers · Henderson Kitchen & Bathroom Designers · Highland Park Kitchen & Bathroom Designers · Beachwood Kitchen & Bathroom Remodelers · Auburn Kitchen & Bathroom Remodelers · Durham Kitchen & Bathroom Remodelers · Folsom Kitchen & Bathroom Remodelers · Portage Kitchen & Bathroom Remodelers · York Kitchen & Bathroom Remodelers · Lakeside Cabinets & Cabinetry · Mount Prospect Cabinets & Cabinetry · Pendleton Tile and Stone Contractors · Rancho Mirage Tile and Stone ContractorsSparklingWaterOriginal Author
angie_diy
rococogurl
rococogurl
rococogurl
a2gemini
