| Kitchen work zones, what are they?
"Zones" are areas in your kitchen where the work occurs. Work in the kitchen is broken down into three primary work zones. Everyone has these three zones, everyone! Prep Zone...This is the zone where food prep takes place. Food prep can be anything from making a sandwich to preparing a multi-course meal. It includes cleaning/rinsing food, cutting, mixing, processing, etc. For many people, especially those with small kitchens, their Prep Zone is also their Baking Center for rolling out dough, etc. 70% of the work and time spent in the kitchen is spent prepping. It's the most often used and longest used zone in your kitchen! Cooking Zone...This is the zone where you take the food you've already prepped and apply heat...cooktop, oven, MW. Only 10% of the work and time spent in the kitchen is spent actually cooking. This is the least used Zone, relatively speaking. Think about it, you usually don't spend the entire time standing in front of your oven or cooktop watching it cook. Sure, there are some things that do have to be stirred constantly, but most things are not. And even then, you usually still spend more time prepping before you begin cooking. Cleanup Zone...This is the zone where the dirty dishes are handled! Dishes, pots, pans, etc. 20% of the work and time spent in the kitchen is spent cleaning up.
Prep Zone...works best when it contains a water source and is next to or across an aisle no more than 48" wide or so from the Cooking Zone. Trash & recycle bins should also be in the Prep Zone. Cooking Zone...works best when next to/across from the Prep Zone (see Prep Zone). It's also nice to have a water source nearby as well as trash & recycling nearby. Cleanup Zone...works best when separated from the Prep & Cooking Zones. This can be on the opposite side of a one-sink kitchen from the Prep Zone or it could be in a completely separate location (the latter usually only works well if you have two sinks). Obviously, it also needs a water source and the DW.
Dish Storage...works best when it's near the DW and near the serving/eating locations (island, DR, Nook, etc.) Food Storage...works best when it's near the "action". It's nice to be able to store staples, etc. at their point-of-use, so food storage can be spread throughout the kitchen. E.g., flour, sugar, etc. in a "Baking Center", spices in the Prep or Cooking Zone, Cereal close to where breakfast is eaten, etc. If you have a dedicated pantry, it's nice to have the pantry near the point where the groceries enter the house as well. Refrigerator...works best on the periphery of the kitchen so it's easily accessed by people working in the kitchen as well as "outsiders" looking for a snack without the "outsiders" getting underfoot of those working in the kitchen. It should also be near the Prep & Cooking Zones inside the kitchen and, if possible, near the main meal location(s) for ease of access during mealtime. Microwave (MW)...this also works best on the periphery of the kitchen so it's easily accessed by people working in the kitchen as well as "outsiders" looking for a snack without the "outsiders" getting underfoot of those working in the kitchen.
When designing your kitchen, ideally, the zones should follow the normal/usual workflow in a kitchen: Refrigerator --> (Prep) Sink --> Workspace --> Cooktop/Range --> Table OR (Cleanup) Sink --> (Cleanup) Sink --> Cabinets (dishes, pots/pans, etc.) Which translates to: Refrigerator --> Prep Zone --> Cooking Zone --> Serving Zone --> Cleanup Zone You don't necessarily have to have this exact flow, but something close. For example, you might have the Cooking Zone located between the Refrigerator and Prep Zone. This isn't necessarily bad b/c these two zones are tied so closely together. On the other hand (OTOH), it's not a good idea to put the Cleanup Zone between the Refrigerator and Prep or Cooking Zones on the same run or on the same aisle if it's a narrow aisle. In this case, the DW and someone cleaning up and/or unloading the DW will be in the way of anyone prepping or cooking because the refrigerator is an integral part of both prepping and cooking. And, of course, the reverse is true....someone prepping and/or cooking will get in the way of someone cleaning up!
Common Zones, Appliances In That Zone, and Suggestions For What To Store There:
Less Common Zones:
Overlapping of Zones Due to space constraints, some zones often overlap. If this is the case in your kitchen, be sure there is enough work space in the overlap for both activities. Zones that commonly overlap...
| This is a "Read Me" subject thread.... [Please, do not bump this thread!] |
