Read Me If You're New To GW Kitchens! [Help keep on Page 1]
Posted by buehl (My Page) on
Wed, May 4, 11 at 8:10
Welcome! If you are new to Kitchens, you may find the following information and links helpful.
The Frequently Asked Questions (FAQ) pages contain helpful information about how to navigate this site as well as the world of kitchen renovations.
The Kitchen Forum Acronyms will help you understand some of the acronyms used frequently in posts.
The Finished Kitchens Blog has pictures and information about many GW members' finished kitchens. Not only can you see them alphabetically, but there is also a category list if you're looking for specific things like a kitchen w/a Beverage Center or a kitchen w/a mix of dark and light cabinets. Access the FKB Categories Page via a link in the navigation panel on the right of any FKB page. Additionally, there is also a link to "In-Progress Kitchens" for those members' kitchens that are not quite ready for the FKB. There is also a link to "Coming Soon Kitchens" for those kitchens that are ready for the FKB but have not yet been added. To access the "In-Progress Kitchens", the "Coming Soon Kitchens", and the "FKB Categories", see the links in the navigation panel that is on the right side of each main FKB page.
The Appliances Forum is very useful when you have questions specific to appliances.
To start off the kitchen remodel process...take the Sweeby Test. Then, move on to Beginning a Kitchen Plan.
Other topics such as layouts, planning for storage, and stone materials are discussed in later posts in this thread. Even more information can be found by doing a search on the forum.
Tips:
  • Before posting a question, please search the forum. There's a very good chance someone has already asked the question.
  • When using the "search" function, be sure to use the search box on the bottom of the page, not the top!
  • Note, however, that you will probably have better luck searching if you use Google (or similar search engine) than if you use the Forum search function. When using Google, to limit your results to Garden Web, include the following in your search criteria: ***site:ths.gardenweb.com
  • In the Subject, the site changes the double quote used as the inches indicator (") to a single quote ('). We don't know why. To compensate, use two single quotes and it will appear as a double quote in the Subject. Luckily, the double quote works in the message box.
  • When composing a new thread, you have a couple of options:
    • Have replies emailed to you: check the box offering this option. However, you must have "Allow other users to send you email via forms at our site." box checked in your profile for this to work (see the "Your Profile" link at the very top of the page) [See the post later in this thread with the Subject: Getting Emails Sent To You...3-step Process]
    • Insert a link: When you "preview" your message, you will be provided with two boxes for a link...one is for the link itself and the second is for the name or description of the link.
  • When using the "Clip this post" option (far upper right corner of each post, small print), remember that only the current post is clipped, not the entire thread. Also, you are allowed a maximum of 50 clippings. Once you reach this max, you will no longer be able to clip or email posts.
How are the home page and the Forum organized? (based on the Kitchen Forum's FAQs entries)
  • The Kitchens Forum home page lists 30 thread titles, starting with those that don't yet have a response. Then threads are listed in order of most recent response. That first page displays the last 2 hours or so of activity. (If there is no response to a thread in an hour or two, the unanswered thread starts to drop.)
  • Below the thread list are page numbers 1-67 for the total 67 pages of threads available -- capturing maybe 2 months or so of threads, less when the Forum is busy.
  • Below that (and at the top of the thread list) is a space for you to switch to the Conversations or Gallery "sides" - these are set up similarly but are not nearly as active.
  • Next down is a Search box -- very important! This is also the Search box you should use (not the one at the top of the page.)
    • Always refresh the page two or three times b/f assuming a thread has disappeared right after starting it.
    • As to searching...a thread will not be found during a GW search for up to 24 hours after it has been started. This may seem too technical, but...searches are done against what are known as "indexes". Indexes use key fields/words to find things. iVillage only indexes threads once a day. So, that means that until your thread is "indexed", it won't show up in a search. If you start a thread just before the index is taken, you will be able to retrieve your thread by searching soon after creation. If, however, you start your thread right after the daily index, then you will have to wait almost 24 hours for the next index.
  • Next is a place for you to start a new thread. And finally there are some instructions and links at the bottom.
Kitchen Forum "Sides"
Discussions: This is the "side" you are on. It is for on-topic discussions concerning kitchens...renovations, use of, etc.
Conversations: This is the "side" where you can post off topic threads such as regional get-togethers and non-kitchen subjects.
Gallery: This is the "side" where members often post pictures...especially if you're posting a lot or a finished kitchen. (Note: This is where StarPooh, our FKB person, wants you to post your finished kitchen prior to having it added to the FKB.)
Again, welcome and good luck! The journey is wild, sometimes bumpy, but fun and very rewarding in the end!
How THIS thread is organized
To make this thread more readable and to make it easier to find a specific topic, I have created separate threads for each topic and just point/link to them from here.
We will continue to bump this thread, but not the other threads I created. Please, do not bump the "subject" threads I will be linking to from here. We do not want to flood the first page with all those threads. To do so would knock threads from members asking for help, etc. off the first page and would be counter-productive!
Posting a Link
Posting Pictures
Layout Help
What information we need and how to draw up and label a floor plan.
http://ths.gardenweb.com/forums/load/kitchbath/msg010521247761.html
A piece of advice: When you post a layout for comments, please do not take the comments you receive personally. Everyone here is trying to help, not criticize maliciously. We want you to have a kitchen that, in the end, functions wonderfully well and looks nice overall. This may mean that some of us may tear apart your layout and rebuild it to what we think will work better, but it's done with good intentions. We're not the best at just "validating" someones layout, we're best at critiquing!
I will warn you that most of us here are "function over form" (or "function first")...meaning we strive first for a functional layout and then fit the form or look around it. It is far easier to make a functional kitchen look nice than it is to make a nice looking dysfunctional kitchen functional. So, if you are a form/looks over function person, be sure to state that when you post.
Some people here think "function over form" means that we want all kitchens to look the same....not true! What we do want is all kitchens to function well...which means that in 99% of the cases, the workflow is the same...so that will mean some similarities due to workflow. However, as each kitchen is unique, each will have its own unique quirks, etc.
In the end, remember this is your kitchen. You don't have to make any of the recommended changes if you don't want to!
[Note: If you're just posting for validation of your layout (i.e., you don't want comments that suggest changes), state that as well. If you don't, people will comment on it!
Warning: People may comment anyway, it's tough to let a kitchen go that you think is dysfunctional and will cause angst later...especially if it's not yet installed and we think we can help. Bear with us, we're just trying to help!]
The Next Step...Planning For Storage
Planing your storage, including where items are commonly stored.
http://ths.gardenweb.com/forums/load/kitchbath/msg010523449014.html
Kitchen work zones, what are they?
What are zones and how do you design with them in mind?
http://ths.gardenweb.com/forums/load/kitchbath/msg0508230128712.html
Miscellaneous Information
Contains:
  • Links from the "Read Me" thread
  • Pantries
  • Useful Information (NKBA links, Other Forums)
  • Helpful Threads (a myriad of past & present threads containing useful/helpful information)
  • Tile Information.
  • Stone Information (how to shop/test/install stone counters, how to remove stains)
  • Cleaning Your Kitchen
    http://ths.gardenweb.com/forums/load/kitchbath/msg0105344116836.html
  •  o
    Bookmarking & Saving Threads
    Bookmarking threads so you can find them later or saving them so you have them (and associated pictures) ''forever''
    http://ths.gardenweb.com/forums/load/kitchbath/msg0105292031876.html
    Eliminating Those Pesky Inline Links in Messages (Advertisements)
    How to Seal Your Stone
    Steps to sealing a stone surface, if it needs it.
    http://ths.gardenweb.com/forums/load/kitchbath/msg0105254810134.html
    Gel Stain Instructions
    RE: Read Me If You're New To GW Kitchens! [Help keep on Page 1]
    bump
    bump
    ~bump~
    bumping to Mambo music this morning--I've been reading "Mambo Kings Play Songs of Love" (and am decidedly NOT a suburban housewife at this morning)
    www.mambo-inn.com click on the reproductor.
    bump
    bump
    Happy Saturday night!
    bump
    Happy Mother's Day!
    bump
    ooomph
    say wha....?
    OK, now I'm seeing double. This is pretty voodoo. There are two of these posts, one on p. 1 and the other on p.2 . My bump does not show on the p.2 one but when I try to bump it it rejects the message as my having just posted. I've refreshed the screens ....
    You know, some problems are just no worth solving.
    gayoink?
    Huh? This is the one that was on p. 2 .... geeesh. Does this mean it's time for some sleep???
    Bump
    Bump
    Hoist ye sails thread.
    Back to the top
    bump
    owdaheya
    Booshoo!
    bumping.....
    bump
    bump but be careful not to trip. It's Friday the 13th!
    All ready to rock N roll
    Bumping back to page 1!
    bump
    bump
    ~bump~
    bump up
    bump
    bump
    ***bump***
    Bump!
    ~bump~
    *bump*
    ~bump~
    bump
    ~bump~
    Boo-joo!
    Bumpity Bump!
    bump
    bump
    bump
    bump
    ~bump~
    bump
    bump
    bump
    thanks for the great info
    ~bump~
    Bumping
    bump
    burp
    bump
    bump
    bump
    Happy Memorial Day Weekend!!
    Happy Memorial Day weekend!
    ~bump~
    Bump bump bump
    bump
    ~bump~
    bump
    Bump
    bump
    ~bump~
    Happy Hump Day! :))
    bump.
    bump
    bump
    I found this on page three
    ~bump~
    bump! bump!
    bump
    ~bump~
    ***bump***
    ~bump~
    bump
    bump
    bumping up from page 2!!
    ***bump***
    I bumpeth.
    Boomp
    Bump-where is summer?
    ~bump~
    ~bump~*~bump~
    bump~summer's here in New England! If only for today.
    bump
    Let's bump again, like we did last summer....
    bump
    bump
    Time for some humanities..."Happy We" by Handel, the silliest classical piece I can think of.
    Here is a link that might be useful: Happy We!
    bump
    bump
    bumping back to the top of page 1!
    bump
    bump
    ooomph
    ***bump***
    Bump
    Oompa!
    ttt
    Bimp..
    bump
    Okay, so I'm new and my post was deleted...why? It was asking about hood venting and making more vertical space in a small-ish kitchen. Sorry I offended anyone...
    nm, it wasn't deleted - sorry, these boards are a little confusing compared to others I have been on! Sorry for the double post into appliances as well :(
    ***bump***ing***bump***ing***
    bump
    bump
    Bump
    ~bump~
    ~bump~*~bump~
    bump
    bump
    thank you
    Bop bop bop,
    bop to the top
    bump
    bump
    bump
    ~bump~
    ~bump~*~bump~
    ***bump***
    bump
    ~bump~
    bump
    bump
    ***bump***
    ***bump***
    bimp
    bump
    ~bump~
    Bump!
    ***Yikes, page 3!***
    bump
    bump
    ~bump~
    bump
    bump
    Please Note: This thread has reached the upper limit for the number follow-ups allowed (150). If you would like to continue this discussion, please begin a new thread using the form on the main forum page.
