Can I see your non-built in microwaves?
Posted by farmhousegirl (My Page) on
Tue, Apr 10, 12 at 21:25
I don't think I want a built in microwave this time. Our current one is built into the island and it's broken twice. The push button will not fling the door open. We replaced in two years ago and now the new one is doing it again. Right now I'm using a knife to pry the darn thing open each time I need to use it. If it wasn't built in, I could just stick any old micro in that hole. I'm not sure if it will look sloppy to do this in my next kitchen...
Anyone just stick it in the pantry? I would love to see your non-built in micros or hear why we should build it in. Thanks everyone!
RE: Can I see your non-built in microwaves?
Here's mine. Building it in would have taken away needed base storage or would have been too high on the upper. I did paint the outside to match, but it sits on the counter in a corner. In my next house I probably will not build it in either, but it will sit on a shelf or in a pantry.
My hesitation to build in a MW is just the issues you have had-too hard to repair or replace. Ours is on an adjustable shelf. Replacing the MW was easy because the space could be enlarged for the new MW. This is the old MW here:
Here is a link that might be useful: a couple more pictures
Ours is on a lower shelf next to the range. It's over 25 years old and won't die! We use the microwave so much we have a 2nd on the counter (in the sandwich area). Once the kids leave for college we will go down to one next to the range.
Here's a shot of our MW.
Also located in the pantry.
We've always had our MW on the countertop.
When we reno-ed the kitchen we thought about relocating it but felt that below the counter would be too low and upper cabinet, or eye level, would be too high.
So we left it right where it was.
I didn't want a built-in to avoid the particular situation the OP is in. I'm already on my second MW on this shelf, as something I tried to warm up one day burst into flames....it still worked but was scorched inside and we weren't sure if there wasn't other damage. It cost less than $150 to replace, which is less than most trim kits.
This is an 'in progress' pic--the box and cabinet above are now painted green. If I can't find the same size again, the whole box pulls out, and we can go back having the MW on the counter. The old (hulking) MW was about the size of the box.
I lined the inside of the door with scrap aluminum, so it can be used for landing space for hot pans from the stove.
We're testing out how well we like the MW under the cab before we invest in a more expensive machine and create the built in look. To my surprise, I'm most enjoying the added feature of storing cutting boards on the side and potholders on top as it feels like too much space is eaten up for a MW.
But, I also don't mind / actually like having spaces in the kitchen that are not all perfect and fitted, so this 'look' is working for me right now.
I don't know why my previous pic link didn't work. I could see it in the preview. How's this one?
Wawwwww! My pic won't load!
I give up! It looked fine in the preview!
I also didn't want the expense or potential headaches of a built in microwave. We put ours under the counter of the island. This side of the island faces away from the living areas, and you really only see it if you are standing at the sink, doing dishes.
We were concerned about it sitting so low, but it has worked out well. We use it for basic reheating and defrosting, so the buttons I use are very familiar and I am not usually searching for something on the display. My husband is 6'3", and I am 5'11" and it is still fine with us. I know this is not true for everyone, but this is one area that I didn't feel like fighting for the "best" solution (microwave drawer). It was a compromise I was willing to make and as a bonus, 6 year old DD now helps to prepare her own snacks!
Mine is standing in a tall cabinet, above the oven. To the left and right we installed narrow pieces of cover panel to get a nice finish. Across the top a piece of trim that came with the cabinets.
Oven is by Ikea (as are the cabinets), a matching microwave is available, but the old one still functions well. When it dies I'll probably change it out for another non-built in, because that is the cheap and easy route.
Ours is on a shelf next to the fridge:
CD fridge makes a big difference
Our toaster oven in in the pantry:
We think we have the best of both worlds, by using a microwave concealed in a cabinet with a garage door style hinge:
Microwave in cabinet, open
Microwave in cabinet, closed
Allows easy access when door is opened, while on rare occasions where we're entertaining etc we can close door and it's invisible.
And it's far superior to any built in MW--a terrible idea, they are overpriced, and near impossible to replace when they inevitably fail. And they contain the same "guts" as any $200 Sharp or Panasonic off the shelf unit, as these two companies are the only manufacturers worldwide.
I too did not do a built-in mainly because of the expense. Here you can see it next to frig on a shelf.
Farmhouse girl-glad you asked this question. Love Clinresga's idea, but all of you are wise not spending big bucks on a microwave like I did.
Won't do it next time either.
Wow! Thank you all so much for the great ideas! I'm loving your kitchens too. : )
I'm pretty convinced I'll buy a $99 micro and forget the whole built in thing. Thanks all!!!
I have the same microwave cabinet I see in a few pics above. I bought it because my off-the-shelf MW fit perfectly in it. It's got about 3/4" of breathing room on each side, and some above it.
I just dug the cabinets out of my peninsula and installed the cabinet over here. I really like it now. I put in an 18" drawer base I got at the reuse center, too. Much better than the old particle board 2-drawer, reach-in I despised from the day it was put in to support the peninsula.
Here you go:
I do see some shelf versions I really like here. Always looking for new and better ideas! Thanks for the thread.
$99 Sharp from Costco. Not a prep or work area, aside from making coffee and using the MW.
mw
Christine, you're making progress. Lookin good.
We don't use the microwave frequently, so I hated the concept of giving up a lot of space for it. When we do use it, the doors slide back on a track so they aren't hanging out in the aisle.
clinresga - Totally using your idea for the microwave! I looked at every MW at every price point. Couldn't accept the aesthetics. This is a great solution!
Isn't it interesting that countertop MWs just wouldn't "die", even if you are "dying" to get a new one, but the built-in ones are usually the first to go of all your appliances?
The built-in MW that came with the house was old and ugly but we couldn't remove it till the oven underneath it broke. So, no built-in MWs for me, thank you very much. My 10 year-old MW is still "live and kicking". When we remodel, I am going to place it on a roll-out shelf below the counter (I think).
Ours is on an upper shelf with adjustable shelves above it.
Our first mw lasted 15+ years, the next one only lasted 1 year. We got our 3rd one about a year before the remodel and I was concerned about longevity. My other concern was new technology. A lot of new ways of cooking have come along since we moved into this house. I wanted to give our kitchen a chance to accommodate a different type of small oven.
We put ours in a deep upper cabinet with adjustable shelves above. It's an important tool in our kitchen and I wanted it easily accessible. I tend to use the timer a lot.
Our first mw was on a fairly low table but it wasn't as low as an undercounter mw. It was fine at first (for the first 5 years), but we eventually ended up hating it every time we used it. Stooping to put things in and out and to see if the ceiling or back needed to be cleaned got old. As our eyes aged we would have to bend to see the buttons. Dh isn't into cushy but even he eventually started complaining about the lowness of the mw.
My children are young adults now but when young kids visit I'm glad I don't have to worry about them pushing mw buttons.
One thing I would do differently is the location of the power outlet. It's right behind the mw but when plugged in, the mw couldn't be pushed as far back on the shelf as I wanted because of the large stiff plug. DH ended up buying a different style of plug (a flatter one) and was able to swap it out.
I had my fabulous electrician put a plug in my MW cabinet.
It's at the top of the cabinet in the back. That's kind of dead space above the MW. I could put trays or hot pads on top of the MW, without the plug interfering.
I also had him leave a lot of wire behind an adjacent cabinet (the Lazy Susan) so when I eventually have my dream counter top put in, I have leeway.
First I gotta find the counter top I like. Been looking for 10 years. When I find it? You'll be the 1st to know.
Thanks, red_lover!
Electricy & drawers
BTW. After an interesting conversation here regarding microwave drawers, do they qualify as these unloved built-ins? Or do they fall into another category? Or aren't they old enough technology that we don't know yet?
Thanks, red_lover!
@mommyatlaw: thanks. We love the solution. The one worry I had when we first did this was durability of the hinges. They have now survived almost four years of constant use by two teenagers as well as us, and are still in good alignment with no signs of problems. Sadly over the four years I've also forgotten the specifics of the maker and model of the hinges but hopefully your cabinet guy can figure that out. If not, contact me and I'll hunt around for the details.
Ours is similar to several others here. In a cubby. We thought about doing a door to cover it - but it's in daily use if for nothing more than reheating a cup of coffee in the afternoon.
Ours is in a cabinet which can be closed to hide it, but is easy (for us tall folk anyhow) to reach.
One more :)
I don't believe in building in something you don't have to. I also don't believe in spending $1,000 on a Viking micorwave when ive never spent more than $100 and always been happy with my popcorn and leftovers ...
Both time I did a kitchen reno, some jerky greedy KD tried to get me to spend an exorbitant sum for a built in micro.
I like them at eye level. The last time I had it above my double ovens, with a cabinet door that rose up and slid back like a garage door.
This time it is also at eye level, on a shelf inside a cabinet with french doors. I added a pull out shelf below if I need to set something down
We have a pinch point between refrigerator and range, which would have been enormously expensive to redesign. So we found a microwave that would fit kitty-corner below the cabinet, and there is room below for pot holders, etc.
