Is Brizo worth the extra $$ over Delta?
Posted by lovetodream (My Page) on
Thu, Feb 7, 13 at 20:44
After MUCH deliberation (why is this so difficult? I know, first world problems, but still....) I'm debating between the Brizo Solna and Delta Trinsic.
There's not a huge difference between the look but there is somewhat of a cost savings if I go with the Delta over the Brizo.
Is there any real benefit to upgrading to the higher priced, Delta owned, Brizo? Or should I use those (much needed) cost savings in another area of the reno?
RE: Is Brizo worth the extra $$ over Delta?
I bought the Brizo because there was no visible line that showed the spray head. I loved the way it tucked up inside the faucet neck. It's me. It's part of the definition of TKO.
I've bought Delta and Brizo for bathrooms for the new house. The "innards" are the same. Same valves for showers.
I went with Brizo for the single handle lav faucets in polished nickel. Delta doesnt have that finish. I definaltly love the snap up magnetic spray nozzel on the Delta Brizo kichen faucets. If you are not compromising a finish issue to go with Delta I would buy Delta.
Beekeeperswife, I like the Brizo for exactly the same reason, so it's not just you! I'm only in the early planning stage, but I may already be on my way to TKO.
