Wed, Feb 6, 13 at 19:10
- Posted by franki1962 (My Page) on Wed, Feb 6, 13 at 19:54
| We chose to have the hot water dispensor and air accuator and soap dispensor holes added to our facucet hole |
| Skip the air gap IMO. I'm in CA and that's our plan. |
| Does your kitchen need to pass inspection? If so you will most likely need an air gap if you live in CA. Some start with the air gap then switch the air gap to a soap dispenser after inspection. They replace the air gap with a "high loop" under the sink. (Not recommending this but letting you know one option.) |
| My kitchen does not need to pass inspection so I was also thinking I would skip the air gap. That would then be 4 things placed at the sink. What would be a good placement for those? It won't be symmetrical since the faucet will be centered. So, where should the soap dispenser, filter faucet and air switch go? What would look the best? Thanks again! |
