Wed, Feb 13, 13 at 17:15
| I just found that the shelf liner I put in my new cabinets a year ago is sticking, and I am so upset. They are the white grip type found at Bed Bath and Beyond... I also used plastic clear ones which are ok so far, but am reading here to get the Cushy Cupboards or cork from Williams Sonoma as the plastic may eventually be a mess as well. Any thoughts on how to repair my beautiful cupboards from this sticky stuff? And what to use now to avoid more problems in the future? Thanks |
- Posted by mountaineergirl (My Page) on Wed, Feb 13, 13 at 18:15
| As someone else mentioned on another thread, you might try Goo Gone. Or fingernail polish remover. But I don't know what that would do to the finish of your cabinets. |
| I would try cooking oil. Corn oil or the like. It won't hurt the finishes, and fairly often oil will remove the sticky stuff left behind when I soak a label off a jar. After it soaks a bit, try scrubbing with a plastic scrubber. Then, of course, wash the residue off with soapy water and dry immediately. If you find something that works, do post the results for us. By the way, I use Cushy Cupboards and love it on open shelves and in some drawers. Much better than other shelf lining I have used. Much easier to clean than the ridged stuff. |
- Posted by jellytoast (My Page) on Fri, Feb 15, 13 at 0:01
| Careful with that Goo Gone! I just ruined something last week with that stuff because I failed to read the directions carefully. It can definately damage surfaces, so use with caution. Maybe you can try heating up the shelf liner with a hair dryer ... that works amazingly well to remove all kinds of sticky stuff, so it's worth a try. |
