Read Me If You're New To GW Kitchens! [Help keep on Page 1]
Posted by buehl (My Page) on
Fri, Feb 11, 11 at 14:32
Welcome! If you are new to Kitchens, you may find the following information and links helpful.
The Frequently Asked Questions (FAQ) pages contain helpful information about how to navigate this site as well as the world of kitchen renovations.
The Kitchen Forum Acronyms will help you understand some of the acronyms used frequently in posts.
The Finished Kitchens Blog has pictures and information about many GW members' finished kitchens. Not only can you see them alphabetically, but there is also a category list if you're looking for specific things like a kitchen w/a Beverage Center or a kitchen w/a mix of dark and light cabinets. Access the FKB Categories Page via a link in the navigation panel on the right of any FKB page. Additionally, there is also a link to "In-Progress Kitchens" for those members' kitchens that are not quite ready for the FKB. There is also a link to "Coming Soon Kitchens" for those kitchens that are ready for the FKB but have not yet been added. To access the "In-Progress Kitchens", the "Coming Soon Kitchens", and the "FKB Categories", see the links in the navigation panel that is on the right side of each main FKB page.
The Appliances Forum is very useful when you have questions specific to appliances.
To start off the kitchen remodel process...take the Sweeby Test. Then, move on to Beginning a Kitchen Plan.
Other topics such as layouts, planning for storage, and stone materials are discussed in later posts in this thread. Even more information can be found by doing a search on the forum.
Tips:
  • Before posting a question, please search the forum. There's a very good chance someone has already asked the question.
  • When using the "search" function, be sure to use the search box on the bottom of the page, not the top!
  • Note, however, that you will probably have better luck searching if you use Google (or similar search engine) than if you use the Forum search function. When using Google, to limit your results to Garden Web, include the following in your search criteria: ***site:ths.gardenweb.com
  • In the Subject, the site changes the double quote used as the inches indicator (") to a single quote ('). We don't know why. To compensate, use two single quotes and it will appear as a double quote in the Subject. Luckily, the double quote works in the message box.
  • When composing a new thread, you have a couple of options:
    • Have replies emailed to you: check the box offering this option. However, you must have "Allow other users to send you email via forms at our site." box checked in your profile for this to work (see the "Your Profile" link at the very top of the page) [See the post later in this thread with the Subject: Getting Emails Sent To You...3-step Process]
    • Insert a link: When you "preview" your message, you will be provided with two boxes for a link...one is for the link itself and the second is for the name or description of the link.
  • When using the "Clip this post" option (far upper right corner of each post, small print), remember that only the current post is clipped, not the entire thread. Also, you are allowed a maximum of 50 clippings. Once you reach this max, you will no longer be able to clip or email posts.
How are the home page and the Forum organized? (based on the Kitchen Forum's FAQs entries)
  • The Kitchens Forum home page lists 30 thread titles, starting with those that don't yet have a response. Then threads are listed in order of most recent response. That first page displays the last 2 hours or so of activity. (If there is no response to a thread in an hour or two, the unanswered thread starts to drop.)
  • Below the thread list are page numbers 1-67 for the total 67 pages of threads available -- capturing maybe 2 months or so of threads, less when the Forum is busy.
  • Below that (and at the top of the thread list) is a space for you to switch to the Conversations or Gallery "sides" - these are set up similarly but are not nearly as active.
  • Next down is a Search box -- very important! This is also the Search box you should use (not the one at the top of the page.)
    • Always refresh the page two or three times b/f assuming a thread has disappeared right after starting it.
    • As to searching...a thread will not be found during a GW search for up to 24 hours after it has been started. This may seem too technical, but...searches are done against what are known as "indexes". Indexes use key fields/words to find things. iVillage only indexes threads once a day. So, that means that until your thread is "indexed", it won't show up in a search. If you start a thread just before the index is taken, you will be able to retrieve your thread by searching soon after creation. If, however, you start your thread right after the daily index, then you will have to wait almost 24 hours for the next index.
  • Next is a place for you to start a new thread. And finally there are some instructions and links at the bottom.
Kitchen Forum "Sides"
Discussions: This is the "side" you are on. It is for on-topic discussions concerning kitchens...renovations, use of, etc.
Conversations: This is the "side" where you can post off topic threads such as regional get-togethers and non-kitchen subjects.
Gallery: This is the "side" where members often post pictures...especially if you're posting a lot or a finished kitchen. (Note: This is where StarPooh, our FKB person, wants you to post your finished kitchen prior to having it added to the FKB.)
Again, welcome and good luck! The journey is wild, sometimes bumpy, but fun and very rewarding in the end!
How THIS thread is organized
To make this thread more readable and to make it easier to find a specific topic, I have created separate threads for each topic and just point/link to them from here.
We will continue to bump this thread, but not the other threads I created. Please, do not bump the "subject" threads I will be linking to here. We do not want to flood the first page with all those threads. To do so would knock threads from members asking for help, etc. off the first page and would be counter-productive!
Posting a Link
Posting Pictures
Layout Help
What information we need and how to draw up and label a floor plan.
http://ths.gardenweb.com/forums/load/kitchbath/msg010521247761.html
The Next Step...Planning For Storage
Planing your storage, including where items are commonly stored.
http://ths.gardenweb.com/forums/load/kitchbath/msg010523449014.html
Miscellaneous Information
Contains:
  • Links from the "Read Me" thread
  • Pantries
  • Useful Information (NKBA links, Other Forums)
  • Helpful Threads (a myriad of past & present threads containing useful/helpful information)
  • Tile Information.
  • Stone Information (how to shop/test/install stone counters, how to remove stains)
  • Cleaning Your Kitchen
    http://ths.gardenweb.com/forums/load/kitchbath/msg0105344116836.html
  •  o
    Bookmarking & Saving Threads
    Bookmarking threads so you can find them later or saving them so you have them (and associated pictures) ''forever''
    http://ths.gardenweb.com/forums/load/kitchbath/msg0105292031876.html
    Eliminating Those Pesky Inline Links in Messages
    How to Seal Your Stone
    Steps to sealing a stone surface, if it needs it.
    http://ths.gardenweb.com/forums/load/kitchbath/msg0105254810134.html
    Gel Stain Instructions
    RE: Read Me If You're New To GW Kitchens! [Help keep on Page 1]
    ~bump~
    Bump
    Bump - and this is great, thanks!!!
    bump
    bump
    bump
    poke
    ~bump~
    Bump for burghmom
    ~bump~
    ~bump~*~bump~
    Happy Valetines bump
    ~bump~
    boing
    bump!!
    bump
    kapow!
    oomph
    ~bump~
    bump!
    bump
    bump
    back to page one!
    ~bump~
    bump
    pinch*poke*u owe me a coke!
    bump
    bump
    bump
    ~bump~
    ~bump~*~bump~
    bump
    Bump
    bump
    bimp
    ~bump~
    bump
    bump
    Oops, this needs to be bumped from page 3.
    ~^~^~^~bump~^~^~^~
    ~bump~
    Bump
    Bump!
    Bump!
    ~bump~
    bump
    ~bump~
    bump
    bump
    ~bump~
    ~bump~*~bump~
    ~bump~*~bump~*~bump~
    Yeah! for Karen V!!
    Bump
    ~bump~
    ~bump~*~bump~
    Go Gophers!
    And onto first page we go!
    ~bump~
    Great info, really helped! Thx!
    Newby asking about backsplashes needs to see this.
    bump
    bump
    bump
    bump
    ~bump~
    bump
    --bump--
    bump
    ***bump***
    Bump
    bump
    bump
    Go Gophers!
    Back!
    Bump
    ~bump~
    ~bump~*~bump~
    ***bump***
    rolling, rolling, rolling
    up up up you go.....
    Bump
    bump
    ~bump~
    Bump
    bumpity
    bump
    Buuuuummmmppppppp
    Go Gophers!
    Busy today! bump
    bump
    bump
    ~bump~
    Bump
    BUMP.......
    bump . . .
    Bumpin
    ~bump~
    ***bump***
    ~bump~
    bump
    ~bump~
    ~bump~*~bump~
    Bump
    Bumpy bump bump
    Bump!
    ~bump~
    Go Gophers!
    bUmP
    Now I get it, should have read this first! :-)
    Bumping! :)
    bumped
    ~bump~
    A Sunday Bump!
    bump
    bump!
    Image Source,Photobucket Uploader Firefox Extension
    ***bump***
    ***bump***
    ~bump~
    Go Gophers!
    Any hints as to how to get rid of the extremely annoying continually popping-up ad at the bottom of the screen?
    ***bump***
    ~bump~
    ~bump~*~bump~
    badum-bump.
    Bump
    Get back up there!
    ~bump~
    Bumpity
    buuuuuuump
    ~bump~
    bump
    buuump
    Bump!
    bump
    ~bump~
    Please Note: This thread has reached the upper limit for the number follow-ups allowed (150). If you would like to continue this discussion, please begin a new thread using the form on the main forum page.
