Jennair?? What is your feeling or experience?
Pattyjill (
Thu, Feb 21, 13 at 14:12
| Looking for reviews on Jennair. I found a fantastic deal on it! Thanks. |
RE: Jennair?? What is your feeling or experience?
| I have the JennAir counter-depth french door fridge. It's about 1.5 years old. I love it and have no complaints. I emailed the company before I bought it and my model was made in the USA too (not all of them are). |
| We had a circa 2002 Jenn-Air counter depth side by side fridge that worked very well for the 8 years we had it before changing houses. |
| I have all Jenn-Air appliances, ranging in age from a 10-year old dual-fuel slide-in downdraft range, to the French door fridge and dishwasher, which are probably about 5 years old. I have no major complaints with any of them. The range is really loud on the convection setting (which is all I use), the downdraft doesn't work as well as I'd like and every once in a great while the fridge is a little loud. All are what I consider to be relatively minor complaints and probably common to all appliances at one point or another. I'm always a little shocked by the bad reviews Jenn-Air gets. That's not been my experience (and I certainly hope it stays that way). |
| I had a JA dual-fuel slide-in range with downdraft. I absolutely loathed it. The downdraft pulled the flame towards the vent and severely impacted the flame height and intensity. I eventually disconnected the downdraft. Oh, almost forgot - the circuit board was fried the first time I use the oven clean feature. In my new kitchen a JennAir range wasn't in the running at all. Doc |
| I guess in all fairness I should add that while we are redoing our cabinets we are installing an over-range venthood, partly because the downdraft doesn't work great (see Doc's complaints above), although I believe that is common to all downdrafts, but mostly because with a downdraft system you are so limited as to what you can buy (right now if we had to replace we'd have a choice of a JA or a Dacor) and I wanted to leave all our options open when it comes time to replace our appliances in the (hopefully far-off) future. |
| Yes I have a Thermador downdraft now and have never liked it! Will never do a downdraft again! |
| I installed JA gas cooktop and double ovens around...2003? They were good. I currently have a JA electric downdraft range of unknown vintage with the interchangeable burner elements. The convection oven is fabulous and has a really good range (very low to very high temp). he cooktop is as good as an electric cooktop can be. I haven't tried using the grill element. The downdraft works surprisingly well but it isn't ducted so it's a best-suction scenario. Straight into the crawl space. I don't use that unless I'm cooking habaneros. I will not replace it with a downdraft. But I have never had problems with JA appliances. |
