I think I have the worst RTA cabinets ever. I purposely choose RTA, China made cabinets (I know, my bad). I've had tons of problems with the assembly and not being quite as described. The supplier has indicted that they have been assembled incorrectly. I believe thy are just bad quality. They've been assembled by my DH who's a builder and licensed general contractor. The supplier said that something to the effect that be may be a contractor but can't assemble RTA cabinets. Well aren't RTA's meant to be assembled by joe-blow-homeowner with a hammer, nails and glue. Shouldn't take too much in the way of carpentry experience or skills in my never to be humble opinion. When I first presented the problems and photos to the supplier he said he would send an installer out to make sure they were assembled correctly. I asked that a principle of his company also be present so we could come to a solution on site. He never followed up to schedule the visit and is now saying I "refused" his installer and "demanded" a full refund, I didn't. On the BBB complaint I did ask for a full refund, I never demanded one from him directly in any of our communications. Anyway following are pictures and commentary of the problems. There are so many pics that I'll only post a sampling.
What would you suggest I do?
Complaint for:
Faulty/substandard materials
Misleading/false advertising
As we've been constructing the cabinets we've come across some problems. At first we hoped it was limited to one or two of them but it seems to be more widespread and significant than that. I'm including pictures to help explain what's happening with them.
The most prevalent problem, among all the cabinets assembled, is that the face plate is too large. The front face should slide easily into/onto the assembled cabinet and it's not happening. Either the cabinets were manufactured too wide or the grooves (dados) in the face were cut to narrow. When forced into place the face begins to buckle and bulge away from the cabinet. We've had to lay each cabinet face on a table saw to increase the width of the grooves (dados) in the face plate in order for the cabinets to fit together.
{{gwi:1613805}}
{{gwi:1613807}}
{{gwi:1613809}}
{{gwi:1613811}}
{{gwi:1613813}}
Upon further inspection we found this: These photos show one of the major problems with the cabinet construction (before assembly). It appears the original back was cut to small so a ply piece was installed that was too wide throwing the width of the cabinets all off. This has been a consistent problem.
{{gwi:1613815}}
The next problem, again among most of the cabinets, is that the shelves don't fit. They are all too wide and would need to be trimmed down to fit correctly. The only cabinet that the shelves have fit correctly so far is the corner wall cabinet.
All of these cabinets have the shelves positioned on the shelf clip on one side.
{{gwi:1613817}}
{{gwi:1613818}}
We've had problems with all the drawer fronts bowing away from the drawer construction. This is a problem in that they'll bow out from the cabinet, looking odd as well as have an increased chance of damage from water or spills. Each drawer will need at least three screws drilled into them (from back to front) so they'll stay flat and caulking.
The 2nd picture shows a stuffed blue envelope stuffed down in to the drawer front
{{gwi:1613819}}
{{gwi:1613820}}
There are more problems with the drawers in general. Some of them are not fitting into the cavity. So far this has been a problem with the blind cabinet and the 15" drawer base. The drawers are all too wide and need to
be trimmed down to fit.
This is explained better by looking at the right side of the picture.
{{gwi:1613821}}
Also each drawer has had to be notched in order to fit into the brackets. By placing the assembled drawer into the drawer guides as is, they won't close all the way due to the guides hitting the front of the drawer. By notching the inside front of the drawers they will fit into the guides correctly, allowing the drawer to close properly.
The brackets are designed to fit into the holes you can barely see on the left side picture. When placed properly into those holes the drawers did not operate properly.
The drawers are out of square, again just leading to even more problems overall. The square (tool) should fit flat against the drawer front. Obviously this is not the case.
{{gwi:1613822}}
Two of the cabinets (so far) are so out of square as to be a problem. When the drawers are inserted they close fine on one side but do not close on the other side, leaving a gap several millimeters wide, this will be seen in the photos. The cabinets that are out of square are the blind cabinet and the 15" drawer base.
This needs to be updated: Each of the cabinets installed is out of square. There are still 3 more cabinets to construct including the pantry and oven cabinet.
If you look at the 1st picture (on the left) youll see the drawer is a different distance from the backside of the cabinet. The picture on the right (2nd pic) shows that the right side of the drawer closes flush against the face while the left side of the drawer does not touch the face at all
{{gwi:1613823}}
{{gwi:1613824}}
{{gwi:1613825}}
{{gwi:1613826}}
The finish on the outside of the cabinets is adequate but is very poor on the inside of the doors. It's really not finished at all. More like one coat of flat paint, sometimes a very stingy coat at that. I'll need to repaint the inside of all the doors to protect them from wet hands and typical kitchen use (water drips, spills, etc). Updated to say barely adequate on the outside of the cabinets, in some cases not adequate at all. The t is chipped and cracked on at least one door, has been sanded and "fixed" on another door. There are paint drips down the side of a drawer. The only baked paint technology seems to be the fillers as the door paint would be more even and not cracking.
{{gwi:1613827}}
{{gwi:1613828}}
When I first bought these cabinets it was with the understanding that they were 5/8" thick, as per the FAQ from Kitchen ProÂs website ("What is the product made of? The boxes (carcasses) of the cabinets are 5/8" plywood and the fronts are solid wood Â") (they've since changed that on the website as of 1/31). When I originally visited the office I did so with a tape measure in hand to measure the thickness of the cabinets, it measured 5/8". When I realized they werenÂt 5/8". It wasnÂt until after I took delivery that I realized they werenÂt 5/8" thick. I decided to live with it although I wasnÂt happy about it and thought IÂd been misled. I came to find out that the cabinets werenÂt even ½" thick as stated in another part of their website. For the most part the side walls of the cabinets are 29/64" thick but the backs are only 3/16", framed with 29/64" pieces. This really weakens the strength of the cabinets as a whole.
Cabinet thickness is not consistent on the back side of cabinets. Framed in 29/64" plywood and then faced off with 3/16" laminate piece. ThatÂs not ½" cabinet grade plywood construction
{{gwi:1613829}}
{{gwi:1613830}}
{{gwi:1613831}}
The plywood quality is poor quality, not cabinet grade or even shop grade quality. The ply pieces have too many gaps in them. A screwdriver can fit into some of them, this one shows the end of a zip tie inserted.
{{gwi:1613832}}
{{gwi:1613833}}
weissman
jenellecalOriginal Author
Brownsville Kitchen & Bathroom Designers · Hemet Kitchen & Bathroom Designers · Saratoga Springs Kitchen & Bathroom Designers · West Virginia Kitchen & Bathroom Designers · Fort Pierce Kitchen & Bathroom Remodelers · Oceanside Kitchen & Bathroom Remodelers · Weston Kitchen & Bathroom Remodelers · Middlesex Kitchen & Bathroom Remodelers · Avocado Heights Cabinets & Cabinetry · Buena Park Cabinets & Cabinetry · Hanover Park Cabinets & Cabinetry · Potomac Cabinets & Cabinetry · South Gate Cabinets & Cabinetry · Milford Mill Cabinets & Cabinetry · Foster City Tile and Stone Contractorsfnzzy
auntiebubba
sombreuil_mongrel
carrianne22
shappy
pecanpie
fnzzy
loves2cook4six
peteinsonj
bob_cville
remodelfla
Debbie Downer
green-zeus
leesi
collinsuncle
debrashaver
