| NOTE: This is only for stones that need sealing. If your stone does not need sealing, do NOT seal! Sealing stones that do not need it can cause problems later with haze, streaking, ghost etching, etc. If applied inappropriately, the sealer will have to be manually removed to return the stone to it's original look. Stones with an absorption rate <0.25% should not be sealed.
Posted by stonegirl on Thu, Jun 4, 09 at 11:43 Whatever sealer you use, read and follow the instructions carefully and be sure to buff off all excess sealer. For maximum effectiveness, each application of sealer needs to fully cure before the next application - normally about 24 hours. Here is a how-to for sealing: You will need the following:
What to do:
Do not think that more is better. Work with smaller quantities of sealer and properly clean up after each application. Your results will be better than trying a single, heavy handed application. For daily cleaning, just use a couple microfiber towels (one dry and one slightly damp) Clean counters with the damp one - you could add some soap to it if you wished - and buff dry with the dry rag. No fuss, and pretty easy |
| [Please, do not bump this thread!] |
