| Hi All,
Everything was going fine until the final polyurethane coat on my oak floors. I have small little chunks of urethane in the most visible area of the floor. They look like a bunch of pimples (I was hoping they were bubbles during the application--big mistake). The poly was fresh, so I am pretty certain the chunks came from urethane drying in applicator (new applicator). I am so frustrated because I have done the rest of my floors in the past without problems in the final coat. I used semi-gloss oil-modified poly. The finish also ended up too shiny (satin was too dull). I have done some searching and it looks as if I probably need to buff and recoat. I tried samples to see if I could just finely sand or rub out the top layer, but it doesn't look right. Can anyone give me advice on the following?:
Thank you for taking the time to read this post. Any advice would be appreciated!
| Boy, I can't help you with most of those questions, but as for #5: I would suggest you call the manufacturer. They're the only ones who really would know the answer to that question, especially since it could easily be "yes" for one brand and "no" for another. |
| Thanks snarke for your advice--sorry for the late reply! We decided to hold off on recoating for now since I did not feel comfortable going forward without more information. I will definitely find out from the manufactuer about mixing the sheens. |
Return to the Flooring Forum
