| Got here from your Kitchens post. Is it white oak or red oak? Did you pop the wood (with water) first? From what I am seeing there is no amount of poly which is going to get you two the color you want. Did your flooring guy see your inspiration pic? If so, is he color blind? There is NO WAY that color in any way, shape or form resembles your inspiration. If you're set on Minwax I'd probably suggest going like 40-60 Ebony Jacobean, or even 50-50 -- straight Jacobean is not going to get you the depth you're after. We have red oak and wanted that dark look: red oak is notoriously difficult to get to the chocolate color, so my sweet husband did a ton of research and found that DuraSeal Penetrating Stain, and we used Ebony 231, was the way for us to get the deep, rich color we wanted (many of the pre-war apts in NY have red oak floors and this was their magic ticket to the ebony color). This was nearly five years ago so I'm sure other stains have improved their red oak abilities as well .... But first the wood had to be popped by soaking it in water -- that allows the grain to open to absorb the color, and in our house, the deep color. I'm not finding an ideal pic to share so I'll post a couple: The floor and its color look pretty flat, but in real life they have more depth: And in this pic you can better see the grain, although due to the flash it's ultra-highlighted here (doesn't look like this in real life) I'm so sorry, but I think you'll really have to do more stain, but let's face it, now is the time to do it and do it right, because I promise you'll always regret it if you don't. We were living in another state when we purchased this house and had the floors installed (and stained). Even with e-mailed inspiration pics, our flooring guy came up with this color: and it was wrong. We only discovered how wrong it was as we were moving in. So one year+ later, we moved everything out and had them redone. Pain in the rear? You bet. Worth it? Absolutely. For the record, our flooring guy had used Bona's Ebony stain, but I'd hardly call that color ebony, would you? |
| Thanks for the comment. I went back today to see the floors under natural daylight and WOW, what a difference a day makes. It's now VERY close to our desires color. Whew! |
Return to the Flooring Forum
