Best insulation for floating engineered wood floors
susanlynn2012
REMODELING GUIDESWhen to Use Engineered Wood Floors
See why an engineered wood floor could be your best choice (and no one will know but you)
Full StoryKNOW YOUR HOUSEKnow Your House: The Basics of Insulated Concrete Form Construction
Get peace and quiet inside and energy efficiency all around with this heavy-duty alternative to wood-frame construction
Full StoryFLOORSWill Cork Float for Your Bathroom Floor?
Get the facts on advantages, disadvantages, costs and installation to see if a cork bathroom floor is right for you
Full StoryGREEN BUILDINGInsulation Basics: Heat, R-Value and the Building Envelope
Learn how heat moves through a home and the materials that can stop it, to make sure your insulation is as effective as you think
Full StoryREMODELING GUIDESCool Your House (and Costs) With the Right Insulation
Insulation offers one of the best paybacks on your investment in your house. Here are some types to discuss with your contractor
Full StoryMATERIALSInsulation Basics: What to Know About Spray Foam
Learn what exactly spray foam is, the pros and cons of using it and why you shouldn’t mess around with installation
Full StoryGREEN BUILDINGEcofriendly Cool: Insulate With Wool, Cork, Old Denim and More
Learn about the pros and cons of healthier alternatives to fiberglass and foam, and when to consider an insulation switch
Full StoryVACATION HOMESA New Prefab Floating Home: Just Add Water
With Friday’s FloatWing prefabricated modular units, life on a boat just got a little easier
Full StoryREMODELING GUIDESLaminate Floors: Get the Look of Wood (and More) for Less
See what goes into laminate flooring and why you just might want to choose it
MiaOKC
nerdyshopper
Alexandria Flooring Contractors · Lexington Flooring Contractors · Medway Flooring Contractors · Murfreesboro Flooring Contractors · Sachse Flooring Contractors · Sarasota Flooring Contractors · South Plainfield Flooring Contractors · Taunton Flooring Contractors · South Holland Tile and Stone Contractors · Augusta General Contractors · Lakewood General Contractors · Pacifica General Contractors · Port Saint Lucie General Contractors · Roseburg General Contractors · Rossmoor General Contractorssusanlynn2012Original Author
nerdyshopper
