- Posted by floorman67 (My Page) on Thu, Dec 1, 11 at 12:49
| I would use "floor patch" to add additional height and feather out the height differential to within the flatness tolerance listed by the hardwood manufacturer in their installation instructions (usually somewhere near 1/4" in 8' to 12'), as well as slightly back-beveling the hardwood that meets the tile if there is any gap because of the additional angle the feathering may create. By the looks of your tile joint shown in your picture, you will not get a perfectly flush transition anyways, because you already have lippage in your tile installation at the doorway that will prevent it. But you can get it close. If you want a perfectly flush transition, that tile needs repaired because it appears to be improperly installed. Lippage can easily be mitigated, and even totally prevented, by controlling the amount of thinset mortar applied and utilising adequate force when setting the tile in combination with a straight edge or level set accross the joints. |
| First of all, do NOT tile over the subfloor even if sealed, it is not the proper substrate for tile. I would bring the wood floor slightly higher than the tile then cut the bottom edge off of the groove on the flooring forming a rabbit and have it cover the seam in the tile. |
- Posted by woodfloorpro (My Page) on Fri, Dec 2, 11 at 10:59
| Consider adding plywood under your thin wood floor to bring it flush. I would leave at least a 3/8" gap next to the tile and fill it with a sand grout caulk or a wood tone one to allow for expansion & contraction. By adding the plywood you will also match up height wise with most other flooring materials the wood floor abuts. |
Return to the Flooring Forum
