Making my own wood filler or buy some
Posted by brusso (My Page) on
Sun, Nov 20, 11 at 15:05
I have a wood floor that I installed, red oak. I need to fillin some cracks/nail holes and was considering using the sanding dust mixed with glue. I saw this on a TV remodel show. The alternative is to buy some filler. My past experience is that purchased filler does not stain that well. I think the self mix stuff is better for staining. My question is:what ratio of glue to sawdust, what kind of glue, do you mix stain in the glue?
Thanks.
PS this is a spare bedroom in my house. Not too big a rush to get it done. But need by Christmas.
RE: Making my own wood filler or buy some
Stain and finish the floor, then use matching filler.
You can even blend the available colors to get a better match.
I may differ with brickeye here. If you are referring to a custom floor then fill the floor first, prior to the final sanding. Your glue- fine sand dust method will work but is more tedious than an off the shelve product.
If it is a prefinished then I would fill last with a precolored filler. Keep in mind most have an oil base that needs all the residue cleaned so not to leave smears on the surface that attract dust. The glue version would be much more trouble to clean up, stain and seal.
"If you are referring to a custom floor then fill the floor first"
And then every single repair spot is going to show since pigment stains (normally used on floors) do not take to sawdust & glue filler anything like actual wood.
Sawdust and hide glue filler is used with aniline dye since it takes the dye very close to solid wood (at least for the water soluble aniline dye).
Paste filler for large scale grain filling is tinted also so it will blend with the final color.
You can use contrasting paste wood filler for certain decorative effects, but be aware it does NOT take ANY stain or dye like solid wood.
