| Hello,
We are installing 3/5/7 random width 4 side bevel oak flooring in our great room remodel. I wove it into existing (a pain in and of itself). We are 90% done, but now I am a bit stuck. It is about to run into the doorway to the dining room, which is 2" flat oak flooring (tight, no bevel or gaps). So the transition will be oak to oak, but they are different styles. My options:
Am I missing an option? What is commonly done? When I google this, I get mostly results for tile to wood or wood to linoleum -- that kind of stuff. Thanks in advance! Anthony |
| "not sure how I'd cut the existing floor across in a doorway. No room to get a saw or router in there, at least not all the way." You do the ends by hand (back saw and chisel come to mind). You could try a multi-tool to speed it up a little. |
| One way I have used repeatedly is to lay the second floor reasonably tightly to the first, then route out a recess to hold a flush filler strip. It is a lot easier to make the filler strip fit tightly (like beveling both long edges) and then hide the few face nails required. |
| Okay, I think I see what you are getting at. I should be able to lay flooring into the doorway with ease and then maybe screw down a straightedge to the door frame (or pocket screw it in place) and route a perfect line. Then it would be alot of small adjustments, but I'd rather do that on one filler strip than every floor board. I should have said, the boards meet this doorway edge on, that is, the boards are the long part of the T and the doorway is the top of the T. Thanks. Anthony |
Return to the Flooring Forum
