Return to the Flooring Forum
Trafficmaster allure problem
Posted by buzzard1 (My Page) on Wed, Nov 21, 07 at 7:41
| We have had Traffic master Allure installed by HD. The edges are coming up. Anyone have that problem?? |
RE: Trafficmaster allure problem
| How long since the install? I installed some of that flooring and did find some edges slightly raised in spite of my best efforts. |
| After one week. They suggest "rolling" it to get glue to set?? your thoughts?? |
| I did rent and use the 100# roller. A few days later, the floor had not been used, the edges were up a bit, so I hammered them down. Now up again. Time will tell how well it all works. |
| Have Home Depot coming out with a roller on Tuesday. Hope to get this settled. Will keep you posted |
| Please post the promised update. |
| They came out with smaller roller and heat and it's been a couple of weeks and it seems OK. They rolled the entire floor and Home Depot says now Trafficmaster recommends that as part of the install process. Im not sure I would do this floor again.... |
| Heat? How as the heat generated and how was it applied to the floor? The temperature was over 80 deg when I did my install. |
