Wed, Oct 19, 11 at 21:04
| I have an art studio that was built on top of an existing 1934 cement garage floor. The floor was painted with an epoxy paint that is still gassing off 4 months later. I cannot be in the studio without all the doors and the windows open and even then I get a headache after 20 min. I am looking for some expert advice on how to get rid of the odor. |
| Sounds like it may have been out of date or not mixed correctly. Turn the heat up high an try an vaporize whatever is bothering you. |
| Once cured, epoxy 'anything' should not outgas...period. Do you use oilbase paint in your artwork? |
| "Once cured, epoxy 'anything' should not outgas" If mixed correctly. Screw up the proportions ad some of the initial material will remain unreacted. |
Return to the Flooring Forum
