Wondering about stability of hardwood flooring over garage
Posted by kiki_thinking (My Page) on
Mon, Oct 10, 11 at 8:55
I have read that for flooring to be stable, that temperature and humidity must be controlled. Our family room is over our garage. Last year, all of the garage ceiling drywall and insullation was removed in order to do structural work. So now there is a plywood floor over the garage. Some work still remains to be done before the garage ceiling can be re insulated and redrywalled. Can i go ahead and install my hardwood flooring in the family room? I would like to use 4" wide boards, am open to engineered or solid hardwood.
We currently have just plywood underlayment in the family room. If i can't lay hardwood at yhis point, then i need to go ahead and carpet to get the room functional.
Thanks for any help and advice!
RE: Wondering about stability of hardwood flooring over garage
Hey, well you�re correct your wood floor needs to come to EMC which is equilibrium moisture content with temp approx. 50-70 degrees and relative humidity to be within 30-50 percent. Basically your flooring needs to have 6-9% moisture content in it, so that it does not expand or contrast. More detail you can read in maintaningwoodfloors.com/.
You home needs to be always under normal living conditions year round, even if you go on vacation for two weeks. As long as you have your space controlled you should hopefully not have any issues. If you have any more questions please let me know - Steve
Here is a link that might be useful: Flooring
That is what i am trying o figure out alough i didnt know the terms. If my family room floor wjich is plywood, is over my uninsulated garage ceiling, will there bee too much temperature and humidity fluctuation for hardwood flooring?
What data ranges am i looking for?
Thanks again for the help!
