Installing floating floor next to window and sliding door
Posted by hifixer (My Page) on
Thu, Oct 4, 12 at 2:18
We're going to be installing floating floor planks. I know that we can use quarter round molding around the walls but how do we finish off the floor next to the floor-to-ceiling window and the closet sliding door?
The planks are 3/8" thick. The bottom frame of the window is 15/16" high. The height of the rail for the sliding door is 5/8". What kind of trim can we use for this area? Or do we not use any trim?
If anyone has pictures of what it should look like, please post them.
RE: Installing floating floor next to window and sliding door
The windows would generally be finished the same way as the walls and the sliding door would use a reducer or a saddle ripped in half. Most of the flooring manufactures will make a reduce in the same finish as the flooring. Some may have a tongue or a groove on the back edge that would need to be ripped off on a table saw.
End cap should work the best for your case. See the link below to the profile.
Here is a link that might be useful: End cap( Square nose) profile picture
