Fri, Sep 2, 11 at 9:32
| Could someone please explain the difference between a high gloss finish (such as Diamond's) and a piano finish on a laminate. I'm assuming that the piano finish is more durable but just how much more? |
Here is a link that might be useful: Diamond laminate
| High gloss and piano finish are both terms used for a higher luster finish on a laminate floor. Basically mean the same and I would not read durability into those terms at all. Do your research on both products to determine what is best in durability. |
| Thanks, Floortech, for replying to both of my posts. I also saw Bruce Park Avenue laminate with a "piano" finish and wasn't quite sure of the difference between the Bruce and the Diamond. As you said, both finishes are a high sheen. I guess that durability will be according to the AC rating. |
Return to the Flooring Forum
