Advice please! Dust/dirt with engineered floor installation?
Posted by Madeline616 (My Page) on
Mon, Sep 19, 11 at 9:03
Hello all,
I'm having engineered wood flooring laid tomorrow in my closet and bedroom. It's floating, not glue down.
The floor store told me to just remove everything from the floors of the closet, as well as the bottom row of hanging clothes. They said I can leave the items on high shelves and clothes hanging higher off the ground, because the process isn't that dusty (whatever cuts are needed, they do outside.)
Just wanted to run it by the experienced GWers to make sure this is the case. Emptying out all the higher clothes/items will be quite a project today, so I'd love to just leave them. My only experience with flooring is having bare wood laid, sanded, and finished inside the home...that was a real dust fest!
RE: Advice please! Dust/dirt with engineered floor installation?
In our experience, the installer is correct. When we installed our engineered lock floor my husband did all the cutting outside and all it was a matter of was laying the clean/dry piece in place. The installers will be on hands and knees applying the piece so all they really need is light and enough room to kneel. (my DH wiped the piece after cutting to remove cutting dust) Hope this helps.
Thanks so much, tyjy :)
A little residual dust that hangs on the boards from cutting them, but nothing like a sand and finish job.
is there existing flooring that needs to be removed ?
if so that could get a little dusty when removing, preping, and sweeping, unless they use a shop-vac.
