Return to the Flooring Forum
To Paint or To Not Paint the Quarter Round
lt_dan (
Sun, Aug 1, 10 at 16:47
| We just purchased our first home and are in the process of installing laminate floor in both the kitchen and dining room. The dining room was carpeted (which isn't a good combination with a toddler- too messy) and the kitchen had vinyl.
I've prepped the subfloor so the two rooms are level now. I did not remove the baseboards. In the kitchen because it only has a baseboard in the pantry. And in the dining room I didn't because it is also attached to the living room- which would have meant I either remove the baseboard on the entire floor or pull off enough of the baseboard to trim off enough for the laminate floor and padding. Either way required too much work so I decided to use shoe molding/quarter round.
That leads to my question, I like the idea of painting the quarter round white to match the baseboard, but what about the quarter round that goes against the cabinets and bar? Would it look funny to not paint those and have one side match the baseboard while the other side doesn't match the cabinets? Or I could just leave it as is and match the floor, but I'm afraid if the baseboard trim isn't white, the quarter round will dwarf my tiny baseboard. |
RE: To Paint or To Not Paint the Quarter Round
| Lt. Dan I just wrote a blog post about this. I hope it helps. http://realwoodfloors.blogspot.com/2010/08/should-i-paint-or-stain-my-
trim.html |
| Inspector, how does your blog post help to answer the question posted? lt_dan, since you have short baseboards it would look better (IMO) to paint the qtr round on the white baseboard, but stain the qtr round beneath the bar and cabinets to match their wood. I have taller baseboards so I stained the quarter round to match the floor, and then used a different shape trim instead of quarter round under my cabinets, stained to match the cabinets. |
| idrive I was just trying to back up his thought to paint the shoe mold that was going up against the white trim and give that visual. My post did not directly deal with his cabinets issue so I apologize if it seemed like my comment was off topic. On that issue I feel like Lt. Dan is on the right track to stain against the cabinet base to match and paint against the white base molding. Of course, we are talking about aesthetic issues which are as much personal preference as anything else. |
| Those pictures were helpful, thanks inspector. For the cabinets, what about spending the big bucks and buying the matching quarter round for the floor? Rather than staining them. |
| Wow, those pics were huge. Visuals rule. Thanks for sharing! |
| I agree, paint the quarter round to match the baseboard, and stain it to match the cabinets. |
