transition strip choices
Posted by myschmoopy (My Page) on
Mon, Aug 13, 12 at 12:13
I have vinyl sheeting, transitioning to stained concrete. It is an even transition but I need something to finsh off. Any suggestions? Definitely NOT those junky metal strips, but I don't know what to use. Anything I see that is considered a transition strip has some type of height from one area to the other.Do I just stain and glue a thin strip of wood? Thanks for input or suggestions.
RE: transition strip choices
A thin piece of stainless, copper, or brass could be custom manufactured to cover the cut edge of the vinyl, but it would still need to have holes in it to be fastened down to the floor. That wouldn't leave it looking much different than a traditional metal transition piece. A thin piece of wood wouldn't have enough structural integrity to hold up under foot traffic. It would need to be a much thicker, traditional threshold to stand up. There are always marble saddles that are more typically used in a bath situation.
You will have to be the judge on the aesthetics here, but you do need some type of strip to hold down the edge of the vinyl. It will be a trip hazard if it works loose.
