Wood floor touch ups
Posted by macvirtualasst (My Page) on
Thu, Aug 2, 12 at 0:51
I am looking for a miracle here:
Is there a substance or machine that can take just the slightest micro layer off of the top of my wood floors and at the same time polish it back up so that I don't need to add more poly? We have oil based gloss varathane on it...I have a few areas I need to touch up...
Thanks for your help...
RE: Wood floor touch ups
You are not going to get your miracle. Screening and recoating is standard maintenance. Do one room at a time so the furniture can move to the adjacent room to clear the floor.
If your floor is still in pretty good shape with no wear-through to bare wood, then you can do what you want with a buff and coat.
Different finish manufacturers have different systems to do what you want here. For example, Bona's system uses a moroon buffing pad and their Prep chemical cleaning agent. Basic Coatings uses a system that uses their Tykote cleaning agent.
