head seam on Smartstrand loop pile
Posted by jrs2831 (My Page) on
Wed, Jun 29, 11 at 18:19
I am replacing the carpet in our master bedroom with Smartstrand loop pile. We have the option of having having one side seam or, for $180 less because it uses less sq ft, the same side seam and then a head seam that will be 3' wide under the bed making a "T" with the side seam. The carpet store is recommending the more expensive option to avoid the head seam, but if it's under the bed I am thinking I might rather save $180. What do you think?
RE: head seam on Smartstrand loop pile
loop carpet will always have a more noticeable seam than a cut pile cpt. Assuming you know the odds of it being noticeable and feel comfortable that it will be hidden than going with the less ydg will be ok for you. Lots of people used to seeing no 'seams' always get upset when buying loop cpt as it can be more visible but not a 'defect'. A good installer will always help but lots of time it has to do with how the light reflects across the seam or how you are looking at it.
If under the bed...save the 180 as it hurts nothing at all and it is being frugal in a tough economy. Just my opinion and a good installer many times can make a head seam look just as nice as a side seam.
