Thinset as grout?
Posted by abchoppers (My Page) on
Sun, Jun 21, 09 at 18:02
Hi all, I'm in New York. I just finished an outdoor patio project which was installing multi color 12x12 slate over a concrete slab. I have 3/8" grout lines. It's 350sq ft.
Can I just use grey thinset to grout with? The color matches fine and it's quite a bit cheaper than grout, plus I thought it might last longer outside.
I used Flexbond to install the tile, but if I can use thinset for grout can I just use the cheaper unmodified thinset?
Thanks all for any replies,
Ryan
RE: Thinset as grout?
First off, I wouldn't use thinset for a couple of reasons. Not only will it shrink and crack in the joints, but it would be a huge PITA to get clean. Additionally it'll "drag" as you run the sponge across the joints
Secondly, I don't know what you were planning on using for grout, but I've yet to EVER see a grout, other than epoxies, that are more expensive than thinset.
Use the proper mortar for each use. You'll be much happier in the longrun.
Thanks for the quick reply. I'll definitely stick with grout then, is just regular sanded grout okay for outside? I'll be sealing it and the slate after I'm all done. Thanks again
