| We are having issues with the final coat of polyurethane. We are not applying it ourselves - we hired a flooring guy to do the work.
Shortened version - first floor guy sanded entire main floor (oak) then laid unstained oak in the kitchen addition and re-stained the entire main floor so all the floors match. He did an ok job with the stain but was terrible with attention to detail so the baseboards are badly stained with both stain and polyurethane, the new floor had to be ripped up because he did not check the moisture content in the thinset in the addition before he laid the new floor. It cupped pretty badly - so we had to tear it all up. There was too much crud (for a lack of better word) sealed into the floors near the baseboards as he did not clean and tack the floors well enough, plus small white paint flecks from our peeling outside porch steps. He did not remove his outer footwear when applying the sealer. He put satin sealer in the kitchen (what I wanted) but the very next week put semigloss on the remainder of the main floor! He did replace the wood for the addition but we decided not to have him continue as our flooring installer/finisher. Enter second flooring guy - did a good job with the addition and staining, re-buffed the semigloss area and applied a satin finish...except he did not use the product we told him was used (Duraseal) so the new satin was still quite shiny. Too shiny for me. So we had him re-do it with the satin Duraseal which was used in the kitchen area. Except - it looks horrible - all streaky with dull hazy areas! He redid it the following day but diluted it 10% - same result! Uggg. Found out today the original flooring guy used a discontinued Duraseal satin that is more user friendly and yields better results. He has the remaining supply of this product in the province. He would come back and redo the final top coat but then when I go to redo the floors upstairs (prob in a few years) there is a good chance this finish will not be available. So now I am stuck with what to do. Go back to the product the second flooring fellow uses and likes (but I would like a less shiny finish) or try to find another product that has the ease of use and sheen I want? I think the product used by this guy was Bono or Bonoline or something similar and I don't know if they make a matte finish..although I would like some form of sheen to the finish. This has been an ongoing flooring headache - almost 4 months worth of issues and we are so close.. |
| OMG....don't take this the wrong way.....but you need to be finding a QUALIFIED Sand & Finish company and let THEM deal with this. If you continue the way your headed your only spending MORE money on a "MAYBE THIS WILL WORK" SCENARIO. |
| Professional grade urethanes aren't limited to Duraseal and Bona. You might also try to find someone who can provide you PoloPlaz (they have both satin and satin matte I think) or Lenmar (theirs is called dull-rubbed). Both easy to work with and both provide a rich look. |
| we had a white line problem and then we found glitsa and it looks great. |
- Posted by joyce_6333 (My Page) on Sun, Jul 31, 11 at 16:30
Here is a link that might be useful: Glitsa Floor Finish
- Posted by woodfloorpro (My Page) on Sun, Jul 31, 11 at 21:44
| The new low, EPA forced, VOC finishes can be nearly impossible to use over large areas so perhaps that is not the finishers fault. Inspector gives sound advise as to good finishes to use. Nice picture of hickory floors! |
- Posted by roberto487 (My Page) on Wed, Aug 3, 11 at 9:54
| I am about to use Fabulon pro Satin Finish. I hear that Fabulon is top of the line and the satin finish is to kill for. So next week I will let u know how everything turned out. |
Return to the Flooring Forum
